XKR Problems - water in engine oil and exhaust
What does your oil look like? Is it a brown gray milkshake looking color? Have you drain the oil? How much fluid came out when you drained it if you drained it. Sometimes water spitting out the tailpipe is just a catalytic converter‘s converting that exhaust gases to water so that’s why you see some exhaust spitting out droplets and it’s not necessarily water in the engine. Tell us exactly what’s going on here.
it just could be residual moisture that condensed inside the engine from a bunch of short haul trips. Sometimes it could be car got flooded. Sometimes it could be a bad head gasket leaking coolant. Some of those I listed are bad. Some of those are OK.
If you have, or wanna buy, a cooling system pressure gauge, it will help. Attach to where you fill on coolant, pump up. Normally it will keep pressure for at least 30 minutes, if you have leaking head gasket it will drop in max 2 minutes.
If leaking head gasket, and you want to find out which side, buy (sorry) good screw in compression tester, and you can find which cylinder/side is faulty.
If both gauges above show normal, you have a normal cooling system external leak and no need to tear off cylinder heads. Good luck
Always diagnose before you let a mechanic or yourself do major work, saves $$$$$$
If it's actually a head gasket, you can buy a cheap chemical tester for the coolant. Since the cylinder pressure is vastly higher than the coolant, a bad HG will force exhaust gases into the coolant. This is chemically detectable. Cheap kit (last I bought one) was $15 or so.
Several other locations can mix coolant and oils. For example, there's a heat exchanger (oil coolant) near the oil filter mount. Can't recall if the ZF uses an air cooler or coolant heat exchanger, but that's always possible.
Received 1,124 Likes
Received 2,012 Likes
OzRisk
06-17-2022 08:42 AM
