View Poll Results: What color is your 2012+ XKR-S?
French Racing Blue
20
26.67%
Polaris White
18.67%
Stratus Grey Metallic
8.00%
Ultimate Black Metallic
18.67%
Italian Racing Red Metallic
16
21.33%
British Racing Green Metallic
6.67%
Voters: 75. You may not vote on this poll
XKR-S Owners check in - Unofficial Registry
#222
Mustang GT-500. Just drove friend's new GT-500. 667 HP, I believe. First of all the car feels massive. Feels bigger than my Audi S7. $65K. No power seats, Paint is dull, etc.,etc. Feels like a truck on local roads. Sounds good. They finally opened the exhaust. First gear is a tire burner which is advertised. Drove for half an hour on country roads. Mechanical package is good. Engine and drive train work well together. Good supercharged throttle response. Surprising lack of midrange torque. Thought it would feel much faster than my XKRS. I do believe the Jag. could get a big jump on it from 40 or 50 mph. I know the Jag is a much more expensive car but but I would take a 65K used Bimmer, Porsche over the GT500 in a heartbeat. I personally think my 86 911 Track car sounds better and is much more fun than tire smoking stoplight drags. I also recognize that these cars perform well on the track but I think they are too big and loose for fast country road corners. That leaves tire smoking.
#223
Has anyone installed michelin pilot super sports on their Xkr-s recently? I was looking to get oem size for the front but they seem to be back ordered and tire rack says they don't think they will be able to get any. I will probably go with larger fronts and rears which are available 265-35-20 and 305-30-20. A member from San Diego installed these a while ago without problems. Has anyone else gone with this size?
#225
On the rear I have the 305/30ZR-20 Michelin Pilot Super Sport XL and they fit perfect.
One of the best things I did was change the tires. The PSS clearly outperforms the PZero on this car, at least for me. Much more grip in the rear, can put the power down now.
#226
I have the 255/35ZR-20 Michelin Pilot Super Sport K2 Ferrari XL on the front, I guess they are discontinued?
#227
#228
#229
OK I didn't know what is your OEM rear tire size. I assumed it to be 285-30/20 (26.8 OD) similar to mine which is a smaller tire then the 305-30/20 (27.2 OD). SO if your speedo is calibrated to the 305 then no problem.
#230
#231
Rich
#234
Matt in Houston (08-20-2014)
#235
#236
#239
http://www.tirerack.com/tires/tires....um=535YR0PSSXL
But you can go wider on the XKR-S, 265 up front and 305 in the rear. Problem solved.
#240
Lothar52 (08-25-2014)
