View Poll Results: What color is your 2012+ XKR-S?
French Racing Blue
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar2-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar2.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar2-r.gif)
![](https://www.jaguarforums.com/forum/clear.gif)
20
26.67%
Polaris White
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar3-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar3.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar3-r.gif)
18.67%
Stratus Grey Metallic
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar4-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar4.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar4-r.gif)
8.00%
Ultimate Black Metallic
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar5-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar5.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar5-r.gif)
18.67%
Italian Racing Red Metallic
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar6-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar6.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar6-r.gif)
16
21.33%
British Racing Green Metallic
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar1-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar1.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar1-r.gif)
6.67%
Voters: 75. You may not vote on this poll
XKR-S Owners check in - Unofficial Registry
#142
Press releases for the 2012 and 2013 XKR-S routinely cited 200 2013's, roughly 50:50 coupe/convertible, and only 25 convertibles in 2012. Guessing at a similar coupe/convertible ratio for 2012 and you end up with a number that's not far from the 270 US cars mentioned above.
I tried contacting Jaguar re: our FRBlue coupe numbers, but they would only supply general stats. My guess would be that there are 20-30 FRB coupes in the US.
EDIT: and add some more 2014 cars... I will up my estimate to 36.5 FRB coupes in the US ;-)
Rich
#145
One of the great things about the XKR-S...I have had mine for almost a year now in a major city and have never seen another one...ever.
My plate says "1 of 25"...One day a couple teenagers pulled up to me and said they loved the car, but wanted to know if I had 24 other cars...LOL.
#146
#147
#148
One tip, when removing the stock ones I recommend you use some blue painters tape on top of the bonnet to hold them loosely in place, perhaps along the edge. Otherwise when you pop them out from the underside of the bonnet they will go flying off and could possibly hit your car or even damage the stock vent if it flies off and hits the ground.
When applying the CF vents, make sure they are perfectly centered and both sides match. You will apply them with the bonnet closed, as they use 3M tape to hold them in place. Simple install.
Post pics when you're done and good luck!
#150
Yes, very easily. The stock amber ones are only held in place by a thick double sided tape. For removal of the stock pieces, you need to warm them up with a hair dryer and then gently pry them off using a small flathead screwdriver. Be careful not to crack them if you plan to save them for later. You can also tape around them and use a washcloth so the screwdriver doesn't scratch the paint while you pry.
The new clear ones will just stick right back in place. Make sure to get all the old tape residue out of the cavity so the new ones will fit in perfectly and securely.
#151
A pic of my car is up on the Jaguar USA Facebook page...lol.
https://www.facebook.com/JaguarUSA
2,856 likes and 313 shares so far. They really played with the color filters, looks like my BRG is Chameleon paint!
Some of the comments are funny...One lady said she loved the "chrome" paint.
#152
2857 likes know. Very nice! Gorgeous shine.
#153
I added the OEM carbon fiber hood vents tonight. I really like the result - I think it helps tie in the CF parts. I still need to install the carbon fiber mirrors but ran out of time this evening. Here's some quick pics...
#154
#156
I did. The Mina's are MUCH less expensive but are mounted using 3M tape and aren't as finished on the underside. I think both are good options, I just decided to go with OEM for the above reasons. I've got the OEM CF mirror covers too but need to figure out how to remove the mirror glass so I can pop off the original covers. Do you know if there's a place I can download the service manual?
Thanks,
Hamish.
#157
hmm, I saw somebody here post a link where you can create an account and login to a Jaguar site that gives you your original equipment list based on your VIN etc and I saw a document section there and it definitely had the owner's manual there but also other docs, not absolutely sure. I have the kink saved at home but cannot find the thread heere right now. I will post it tonight if it has any of the service manuals as well.
Aside of that, many mirrors are just ball clips and pop right off with a little pull.
#158
Thanks,
Hamish.
Thanks,
Hamish.
Jagdocs.com
#159
hmmm, sweet, mirror caps brochure is free
Chrome Door Mirror Caps [Jaguar XK XKR X150] : JagDocs, The Source for Jaguar Documentation!
