Is XKR-S Transmission Control Module (TCM) tuned differently than XKR?
There is a long thread here:
https://www.jaguarforums.com/forum/g...-66558/page19/
I just bought a "Mangoose" and received it a couple days ago:
"http://www.aliexpress.com/item/JLR-Mangoose-for-Jaguar-and-Land-Rover-V134-Newest-Version/1596002378.html"
It actually says Mongoose and even has the Drew Tech label on the back with a serial number. Don't be in a hurry, it comes on a slow boat from China.
Came with v134 software and I am about to install it. There is a crack to prevent the phone home functionality, which had some easily fixed trojan virus in it. MaAfee picked it up right away and cleaned the file with no problem.
Another member reported the same and that it worked fine once the virus was cleaned, so we will see.
I set up a WinXP virtual machine on a Win7 laptop to use as a sandbox for the install. No network or other external access is enabled, so if it does implode when I install it, then no collateral damage.
Panthro (06-17-2017)
Compared to the XKR, the XKR-S has a much greater sense of urgency when you hit the gas... it runs like a scaulded dog!!! YEEEEEHAW!!!!!!!! Other then that I cant explain it.. With regular driving it feels about the same because the dunlap tires are rough - heck the Pirelli's P Zero's seem to give it a smoother ride!Loth
DGL (02-16-2014)
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
