XKR Supercharger 10% Upper Pulley Mod
jahummer (11-13-2020)
https://www.powerhouse.uk/content/ja...er-pulleys.php
My Indy has advised me to go no greater than 6% on my 5l and they are fitting a custom SS 'bolt on' type which are easier to service/remove.
My car already has a 7.5 ali pulley fitted, since this was done prior to my ownership I can't really compare to stock.
As CJ has said a waste without a tune (and zaust mods if yours is stock) there's no point.
Good luck
Good luck
I don’t believe is tune is “necessary“.
The pulley will spin the supercharger faster so it will pump more air and the ECM will provide more fuel so you should be seeing plenty of new power. The tune of course will try to extract more power by adjusting things like the fuel tables and timing and torque management
But the pool alone will give you some horses
Any time air, fuel or spark are modified, the ECU needs to know what to do with this modification. It doesn't already know the requested parameters, so it guesses.
Just a pulley MAY give you a pony or three, but that's not even worth five bucks. Lose ten pounds of body weight instead, it'll have the same result.
TM08XKR (04-03-2022)
Do these engines resort to a preprogrammed fuel map at WOT? If the ECU uses a preprogrammed fuel map at WOT, does the ECU monitor the O2 sensors at WOT and modify those fuel maps if it sees excessively lean conditions?
I thought the it starts with a base fuel map which gets adjusted using the STFT's and LTFT's based on O2 sensor readings......
In SDD, I can look at my fuel trims across the RPM range and Various loads and see the adjustments the ECU made so it does modify the tables based on what it sniffs from idle up to some high rpm range
And I thought the reason people see more power with a programmed ECU is because the programmer can push the limits on things like timing and mixture to increase power over the stock baseline. For instance instead of staying with a factory 30 degree advance max, the programmer can bring it to 38 degrees. and instead of trying to get the mixture to 12.1 AFR the programmer can change it higher or lower for max power.
To the original poster , proper remap will actually allow boost and power from the pulley to be used to full potential. Even with a stock setup power limiters can be hit and for sure with a smaller pulley. Potential gain from 4.2 later cars is 75% in the tune and 25% in hardware modification, so even on a completely stock car there is a huge gain with ECU tune and small in comparison from pulley and exhaust mods. Pm me for details..
MarkyUK (11-17-2020)
