Xkr trans help
Welcome to the forum Mike,
(I've moved your tech question from General Tech Help section to the XK/XKR section for viewing by more members with the same model.)
Doing a 'hard reset' by disconnecting the battery is just clearing the underlying fault code which is then resetting on the next shift. The guys here should be able to advise how to troubleshoot the issue.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
It may be a simple issue now that may be aggravated by driving it.
Off the shelf products will range from $30 to $70,
I run a bluetooth dongle on my OBD2 port (fleabay $20) and the Torque app ($5) on my phone and tablet. Works fine for basic data viewing, code reading and code resets.
Never had a trans fault, so it may require a different route.
I just ordered a Mongoose clone for $80, which I hope will have far deeper reaching capabilities (minor ECU programming capabilities).
Vince
Vince
Vince[IMG
Vince[IMG
https://www.jaguarforums.com/forum/attachment.php?attachmentid=31272&dateline=1359171 726[/IMG]
Search will give you much deeper grasp.
Basically it gives you more direct access to your ECU. Not for the timid as I'm sure you can brick your cars ECU if you do not know what you are doing. Some of the more basic functions should be to Enable/Disable DRL (and other European functions), program new key fobs and much more.
Vince
Before you spend a lot of money on a scanner go to a local garage or AutoZone, Sears or wherever and get them to read the code and get the code not what they think it means and post it. FYI I use a $29.99 OBD reader for my everyday use, it does have its limitations but has given me what I need when I need it. The code is important so write it down and tell us and we can give you the real meaning.
If you read more about the XKR on this forum you will notice a pattern. Pretty much every problem related to this car is because of the battery. Dead or low battery in this car can cause all sorts of gremlins, from frozen intro screen, check engine lights galore, and probably not starting the car... Start there. You have to put the car in "acc" when running your scanner to give it power btw.
You need to get good power to the car and a scanner that will read the car. Put her on a charger for a while and try again. You may need to try a different model scanner. (There is a whole thread dedicated to them here on the site).
The codes themselves gives us something to open service manuals and hunt for possible fixes.
With ASC, Fail Safe and Gearbox errors it should be easier to pinpoint the one item in common with all systems, but still too vague to have you go spending big cash on "maybe" parts.
