XKR unable to start and on lockdown
Put my XKR into the garage for over winter 2 weeks ago and left it unlocked. Needed to take out of garage but when I went to start car several warning lights came on DSC not available, adaptive front light and check pedestrian system. Car failed to start and has now become unresponsive to any key control action and all the controls are not responding and I am unable to open the boot. At the moment the stop / start button is lit as is the front and rear side lights, number plate light and steering wheel controls but I am unable to switch anything on or off.
Any ideas welcome
Any ideas welcome
Any ideas welcome
Any ideas welcome
Arysue (12-31-2018)
Received 2,646 Likes
Charge the battery via the positive post behind the LH rear wheel at 5 to 10 amps overnight.
If the vehicle is not being consistently driven, it must be locked and the remote key fob kept more than thirty feet away. Install a battery maintainer to ensure the battery is kept to a minimum of 12.6 volts when measured across the terminals.
Arysue (12-31-2018)
1st you'll need to see if the battery takes a charge and holds it. It may be bad and need to be replaced. If it does charge up and hold 12.6 Volts then put it on a "smart charger" but NOT a trickle charger.
Arysue,
What year is your XKR? Your Public Profile shows that you have a 2007 XJR.
Dont buy a battery maintainer until after you read this - the definitive battery thread including recommendations for battery maintainers and how to install them.
https://www.jaguarforums.com/forum/xk-xkr-x150-33/xk-xkr-battery-overview-replacement-1 06281/
Stuart
Stuart
jarrettjjackson
03-20-2019 11:17 AM
Undertaker
04-11-2015 10:27 AM
rvsenior
07-15-2014 02:18 AM
