XKR Upper Supercharger Pulley
I have no idea where you are located. It would help you get the info you are looking for if you identified from whence you come and some data about your XKR. If you want a stock pulley you can try one of the dealers listed in the market place or SNG Barrett, etc. If you want a used pulley there are several breakers located in the United States. One is Pacific Motors in the Detroit area and a second is Jaguar Heaven in California. You can find them on the web. Good luck in your search
You can place a free "Parts Wanted" ad in the Forum Marketplace.
https://www.jaguarforums.com/forum/m...tatus%5B0%5D=0
Can I ask why you want a stock pulley instead of the aftermarket one?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
Cee Jay (03-10-2021)
