Driver/Soft is in a differential or it is in one of "main" computers? If I retrofit a differential from XKRS would it affect a software of my car will be still using an old software (XKR, as build)?
Having you there - I know you have changed your vertical links/knuckles for the forged ones (XKRS).
Do you have any idea if XFRS can be a donor of a front vertical link for a X150? They have a slightly different wheel hub (the way how it is mounted in the knuckle) vs X150. Dimensions seems to be the same (mounting point, as a knuckle is a bit bigger). ABS cable connector looks the same etc.
