xkr wont start
OK what is the voltage at the battery. Is it 12.6V or better. If so do a reset by removing the positive and negative terminals from the battery and then touch them together for 10-20 seconds. Then reattach and see what you have. Also how did you charge the battery and with what type of charger.
Received 1,975 Likes
WAG says loose battery terminals but don't have enough info to go off of.
Really need some details. I'm about 40 minutes away if you really need help with it.
GGG (02-20-2018)
