XKRS 2014 Rear Pads
Can anyone please advise on the rear brake pads for my 2014 XKRS
oem pads are C2P25493
I believe these pads have a clip on the inside brake pad ?
I intend to fit EBC yellow stuff pads and new Discs.
Pads are EBC. DP42059R
I am told they don’t have a clip but on the EBC brake web site it clearly shows these as an aftermarket alternative.
Please advise if I can use the existing clip off the old pads?
The oem pads are very expensive and I understand EBC yellow stuff is the best ?
Any advice would be greatly appreciated.
Steve
Steve
I don't have an XKR but various types of clip are often used which are bonded or rivetted to the metal backing plate of the pad itself and are not detachable. You will obviously not be able to use this type of clip of the new pads. Sometimes the clip or shim is held on with simple fold-over metal tabs and this type can easily be removed and transferred to the new pad.
Richard
Richard
Lothar52 (08-21-2024)
