XKRS in storage for 5 months: Battery plugged or Unplugged??
Hi jag lovers,
Next week-end I'll park the jag for the winter. It'll be in an heated garage where I don,t have a full access. I have two choices: Unplug the battery and everything should comeback live easily in april when I'll put the power on.
2nd: Stay plug and go every two months to put a charger on the battery for a few hours... I don't think I can let the battery charger on for all the winter. They have 30 cars in that garage. I guess they wouldn't like to have 30 chargers ON for 5 months!
I don't think the XKRS as so much electronical staying on when parked?
Any toughts?
TX
Guy
Any toughts?
TX
Guy
Battery Tenders are the right tool to keep both the battery and the car happy during storage, just charge in-place. It's pretty well accepted that the electrical draw is minimal... but if the garage owner doesn't agree, I'd think an extra $20 would cover the actual electric bill for five Tenders.
Rich
Rich
Hi jag lovers,
Any toughts?
TX
Guy
Any toughts?
TX
Guy
This will be the best $67.00 you spend on your car.
I use this model CTEK 3300 my Porsche 981 and the Jaguar XKR. One for each car.
Hope this info helps. many other jag owners on this forum use the same charger. I did use a Battery Tender Jr brand, but discarded it as they have proven not to be very reliable and have a tendency to overheat and melt the outside casing. There are several comments made here on the Jaguar Forums reference this issue of long term charging while the car is stored for a period of months.
Here is what the CTEK looks like with the Jaguar logo...sells for over $110
Here is the link to discussion on these forums for ease of review.
https://www.jaguarforums.com/forum/x...storage-80513/
Hopefully this info helps.
The following 2 users liked this post by richzak:
Quebecjag (10-21-2013),
sherbercars (10-23-2013)
I just had my Jag dealer permanently install my CTEK 3300 battery tender (which I learned about thanks to this forum) so that it's completely plug and play and hidden away. It's now very easy to plug it in for the winter months, keeping the cat alive and using very little power, while keeping the trunk fully closed. I bought the charger online and had it installed by the dealer all-in for less than $200. Inflate tires to 50 PSI and patiently await Spring...
Every XK owner on this forum swears by having a a good battery-tender. I like to learn from my elders!
I use the Batyery Tender Jr only on my Honda ATV, but not any cars. It just gets way too hot, and I have a fear of fire when not at home. There is a comprehensive analysis from another Jag Forum user reference the battery tender product. Returns and warranty on the product appears to be very poor.
I have read in many places on this forum and elsewhere that putting the car up on blocks is a bad idea because it puts the car and suspension under loads it does not normally experience. Since the tires are rated to 50 PSI, and that level of inflation prevents flat-spotting, that is what I plan to do.
Received 2,266 Likes
Just come back from my dealer for the oil change and 12 000 km inspection before I put the cat in the garage for the winter.
I've follow some recommandation and get a tender permanently installed on the battery. Cord 's a bit short, but anyways, no trouble and I'm ready for the winter.
I already miss the cat...
Guy
