yet another XKR exhaust question..
#81
My "new car" has a lot of miles on it and it's only a xk so I'm not going to go overboard with performance so my idea for a little more rumble is to remove the front resonator and install two pipes back to an X that will replace second resonator. I will use this JEGS Performance Products 30680 JEGS Narrow Universal X-Pipe - Free Shipping on All Orders @ JEGS and leave the rear box (muffler) alone. From what I've read putting the X in the rear position should limit the chance of a drone sound at hi way speeds. What are your thoughts?
Randy
Randy
#82
Randy
Randy
I'm not sure if the frequencies and resonance will be the same, but, the "X" I run in my high performance mustang causes no "drone'. Then too, a lot of guys attribute the drone, in part, to the muffler style and perhaps it's baffling. I'm going to start by replacing the center muffs with an X, then see where that leads me.... Good luck!
#83
Hi Randy,
Right you are Ken a couple of my past cars have had flow masters that were very droney (if there is such a word) that at hwy speeds it was very hard to talk or listen to music so I started to experiment with H pipes,simply weld a pipe across joining the two pipes,the farther back I put the cross over the less drone (harmonics) I got but I've been out of the loop for a few years since I built my 32 so these X pipes make a lot of sense to me.When I built the 32 I went two quieter mufflers going into single tailpipe under centre of diff and it has a great sound all through the rpm range.
Randy
#84
Randy
Randy
I'm liking your roadster! love the color. What's the power plant?
Probably, should move this to the "general" area, huh?
#85
Randy, just thought of something, do you know about power sticks? These are what a number of the Cobra guys use in the their outside exhausts. I modified a pair for my
E-Type when I got tired of replacing the factory stuff every two years.
they can be purchased in custom lengths. I have found them to be the best sound, outside of a Harley and a Healy.
Are the XKR's pipes only 2.25?
#86
Yes I've seen those but I'm usually limited for length in the cars that I've built although we put them on a friends 66 BB corvette to replace his burnt out factory ones. The engine is a 97 mustang cobra 32 valve 4.6 and yes we are getting off the track of this thread,I hope I'm still ok as the 32 has a Jag diff in it I'm still about a week away from picking up my car so I'm not sure the exact size of the pipes but the X comes in 2.25,2.50 maybe someone will let us know so I can order the X in the right size.
Randy
Randy
#87
Randy
Randy
I should think, someone will chime in with the dia of the Jag's ex. system. BTW, what do you have coming? Mine's an '08 Portfolio that's about 3 weeks out in arriving. I've been putting off delivery until I can complete my garage expansion. I bought back in January!
#88
exhaut noise
hi, bought a07 xkr from a second owner, the exhaust noise is amazing even in idle, if this is what a jag sounds like in the jungle its identical, no xkrs sounds better, have viewed videos and nothing comes near, previous owner said the first owner got from uk and cost 4,500, the rear box seems more of a cylinder shape than oval, with the tail pipes having the small holes in the insides
#89
Hi, perhaps, pics are in order?
Happy Trails....
#90
Did you ever get an answer? What is the diameter of the 4.2L X-pipe? Did you do that mod? If so,how does it sound and is there any drone? Thanks.
Stuart
#91
Howdy Ya'll, First time poster here. This thread is very interesting and one can have many different takes on it. I've read it twice and can't seem to find anyone mention an answer to a question I have. I want to put in the X Crossover pipe and am probably just going to buy on Jegs or Magnum, but have a question. Since there are two silencers, do I swap out one silencer with the X pipe and straight pipe the second silencer?
I have a 2014 XKR and love driving it in dynamic performance mode using the paddle shifters, but it's missing just a little bit of that "don't fu@$ with me attitude" I'm looking for.
#92
See: https://www.jaguarforums.com/forum/x...-0-xkr-195889/
Any design other than the factory Performance Active Exhaust is likely to cause reduced performance, drone, or worse. I'd replicate the PAE as closely as possible.
#93
#94
