For you convert guys
Does anyone know or can they tell me where the proximity sensors are when you remove the top shield in the boot. Do I assume it is a magnetic sensor as I can't seem to find any type of switch on either side of the plastic rail. Also is there 2 switches or 1.
( I realize you are not supposed to put the top down without the screen in place but I have other motives for doing it)
The soft top guru is WhiteXKR (Steve, a.k.a. TheJagWrangler), the designer and manufacturer of the amazing DIY remote soft top kit. Hopefully, he will see your question and reply. Otherwise, you may want to PM him.
I hope you don't cause more problems that it's worth by putting the top down without the luggage separator in its proper place. The Owner's Handbook states: "Do not attempt to open the convertible top manually, as damage to the linkage mechanism may occur."
I'm curious about why you want to do this.
From the service manual:
The Luggage separator position sensor is a Hall effect sensor located on the LH luggage
separator housing bracket. The sensor informs the control module of when the separator is in
the correct position. When the separator is in the correct position there is enough space in the
luggage compartment to stow the convertible top when open.
jagtoes (01-31-2016)
Received 1,975 Likes
Yep, had to remove those brackets to get the liner out of the trunk to do my LED taillight install, and run wiring for my back up camera, and I do recall a sensor and wires on the back side of the bracket.
Jagtoes - Why don't you download the owner's handbook/manual? Here's the link: Jaguar.handbook.downloads
jagtoes,
Yes, I read your last sentence but didn't know if you (or any other forum members) were aware of the potential damage to the linkage mechanism.
But I'm still puzzled by what your "other motives" are and why you can't watch the top retract with the luggage separator in its proper place. I presume you want to "trick" the computer into thinking that the luggage separator is still there, but I'm not sure what you want to accomplish. Are you looking to free up a bit more storage space in the trunk by eliminating the luggage separator?
Stuart
Stuart
jagtoes,
Stuart
Stuart
I've read the manual a few times and I guess i'll need to get a service manual too. Look at it this way if WhiteXKR wasn't curious as to how the top functioned we wouldn't have his modification. He's more electrical than I am so I'll sticks to mechanics. Some people don't need to know how your ears work in order to hear but others are curious to know.
Stuart S (02-01-2016)
I'm an engineer by trade prior to retirement. I enjoy the design efforts involved in mechanical linkages so knowing the top can be a potential problem area I am interested in seeing how it was designed and functions. Nothing to do with additional space but just an exercise.
My XK has not been on the road in 18 months. It sits in the garage tethered to various test equipment and prototypes unlocking its secrets.
I am really looking forward to driving it again some day soon though!
jagtoes (02-01-2016)
Stuart@VelocityAP
06-29-2017 01:39 PM
