You have to see this . WOW what a good deal
Do's anyone know how to put the ebay ad on here to make it easy to bring it up, only 2 days to go.
http://www.ebay.com/itm/181569086619...619%26_rdc%3D1
Received 4,303 Likes
The '07 XK was offered with 18" (Venus) and optional 19" (Carelia) rims. Not sure the 20s were made available on an XK til the following year when they dropped the 18's for 19/20 options.
I know the 20s were available on the XKR in 07, so maybe we had all three.
Still wish I had a set of 18's to help refine the smooth ride of the XK. These short sidewall 19 and 20s make for a much rougher ride than necessary for a GT car...
Make Jaguar oem Jupiter.
Wheel size 19"
Bolt pattern 5 x 108
Hub 63.3
Front 8.5 offset 49mm
Rear 9.5 offset 31mm
Hope this helps .Thanks Bernie
The sizes above were the same for my 2009 Jag XKR PE. The only difference is my wheels were 20".
Perhaps someone on here could answer this .
As stated in my previous post above, Bernie's wheels are standard Jaguar OEM sizes, for bolt pattern and centerbore.
You can reference the following the website for the Jag XK/XKR sizes by year. There are plenty of other websites that will confirm the sizes also.
Here's an easy one to follow.......
Wheel-size.com :: Reference guide for car wheel and tire dimensions such as size, offset, PCD
The only difference that arises with any wheel is the offset or ET.
There is quite a range on the offsets for the Jag MY's.
The link to the above website should anwser any questions about fitment.
Offsets on wheels can be frustrating to figure out, but Jaguar brands have a wide variable in the offsets that can be used. The offset will create a wider stance or narrower stance once mounted on the car. Keep in mind that offsets are sized in mm's so the difference between offset sizes can be very minimal at best.
So the 5 x 108 Bolt pattern is found on all XK/XKR's 2007 to 2013 as well as the centerbore of 63.3 or 63.4. Only difference may be the offsets.
Hope this helps. For new wheels, Sherbercars OEM Jupiter wheels present a great value, however, I am not sure what his reserve is, and what his final bottom line price is. Never-the-less, if you use a 19" wheel, his is an outstanding choice and value.
sherbercars (11-03-2014)
Thanks again Richard,( ONE MORE BID AND I WILL TAKE THE RESERVE OFF ) I dont use my car for the winter , so I dont need them , so I would I would like to see someone who can, than have them sitting there. Bernie
Here is another Specs sheet.
http://www.discountwheelwarehouse.co..._Referance.cfm
