140 FHC wire loom routing
Hello,
I'm starting to route a new wire harness through my car. When i got the car it was stripped down so I have no knowledge of the correct routing. Can someone send my pictures of the route the harness takes leaving the fuse panel and then through the front of the car? Not sure how it routes through the nose of the car and how the headlight wiring feeds to the headlight connections.
Thank you,
mike
Thank you,
mike
Mike the harness is clipped to the inner fender with omega clips until it dips down and runs behind the front lower panel to the other side. Inside the grill opening in front of the radiator the wires for the lamps pass through and go to connector blocks. The wires from the lamps also enter at the blocks and connect there via the blocks. Horn connects there also
