Body stabilization needed for frame off restoration?
Hi all
I'm about to begin the restoration of my 140FHC and I was wondering if there is any need to stabilize the body before lifting it off the chassis? I thought about removing the doors and then welding two square profiles in lieu of the doors on each side to stiffen the body.
Or is that not needed with the FHC roof? The body is healthy and has no significant corrosion, and the workshop manual does not mention anything either.
Any ideas welcome
Chris
Any ideas welcome
Chris
Received 2,192 Likes
You need to take alot of measurements before you mount and for what you are getting ready to do i would definitly weld in bracing . It can be easy to tweek a body just from sitting underits own weight mounted to different areas other than sitting on a frame. Gotta watch a lot of resto and they all hae bracing welded in and take measurements. Whats looks good to the eye often is not to a tape measure.
We also made a dolly to support it with mounting points to match the frame. Notice the adjustable height on the uprights to make sure everything is even in all directions. Yes, the floor pan has been removed and there are no rocker panels in this pic, but with the supporting custom bracing it didn't move.
cazber
08-02-2013 04:30 PM
