Hood and doors uncorroded because they are aluminium, but the other panels look to be very seriously rusted, so much so that one must consider that almost all need replacing, plus the chassis as well. So if you do buy this heap of parts, then you need to budget for a very large sum to restore it. XK chassis can now be obtained from Poland, I understand.
You then also will have the engine to restore/rebuild and all other mechanical parts. Not a job that is going to be finished in a few months, so consider years are needed.
FWIW, I rebuilt a Mark 2 in the 80s and it took seven years, and I had an unrusted body shell !! Of course I was doing a job of work in the week, so could only work on the car at weekends and evenings. Most parts are available for XK120s but are expensive.Try searching the internet to see what prices are like.
PS: I'm not trying to put you off, but it would be better if you could find a better example to restore.
