HS8 question.
HS8 question.
Hello. I am tinkering with a '53 XK120 SE OTS. I was 'encouraged' to fit 2" HS8's and I am disappointed with the low down torque (ie off the line power) they have delivered. They are quite a bit better higher up the rev range but I really wanted to improve the off the line power.
It is a 3.4 with an SE head (not C type), both inlet ports reamed to 2". The engine was rebuilt 1000 miles ago. I have trumpets with foam covers. The needles are standard XJ6 BAW. Powerspark ignition.
Is there any way I can dig myself out of this hole. ? Maybe retard the ignition a tad ? Different needles ?
Any wisdoms gratefully received.
Keith
Keith
http://solwayjaguar.co.uk/wp-content/uploads/2014/05/Fitting-2-inch-HS8-SU-Carbutettors.pdf
https://sucarb.co.uk/technical/technical-hs-type-carburetter-tuning-general
This article may be helpful
Rgds
David
Rgds
David
wouldbeowner
75
05-18-2024 01:49 AM
