Rear Dampers (Shock Absorbers)
The XK120 uses a shortened version of the Mark V chassis and the same suspension, so apart from spring and damper rates, I would think the items are physically identical. However to confirm try this web supplier: -
www.sngbarrratt.com
XK120 shows rear shock part numbers are C7214E & C7214E
Mark V is C3191 and C3192, so different. I suspect this is because the damper setting is different rather than being physically different, but you need somebody more expert than me, I'm afraid
Both dampers are the lever arm type.
www.sngbarrratt.com
jaguarmarkv (06-07-2016)
jaguarmarkv (06-08-2016)
Jaguar Forums Editor
Jaguar Press release
04-07-2016 08:58 AM
