Rewiring an XK 150
I am trying to rewire an early XK 150 FHC USA model.
Can someone please send me some clear pictures of where the turn signal relay should be mounted please? The car was completely stripped down before I got it and all in boxes with the old loom removed. The previous owner had started the installation ... but gave up and I have little confidence in what has been done so I have started over and am checking everything. I think it should be on the left wing but probably under a box cover of some sort. Pictures and dimensions much appreciated if I am correct of the box cover and also of the box covers that go over the main loom where the headlamp 5-way connectors are too please.
I have many questions please as the books I have none of them have clear pictures of specifics. They are usually distance shots of the engine bay and really arent much use!
For instance, the big hole - oblong with rounded corners, upper center of the firewall engine side - what came through here please?
Also, coming out of the sill half way down the length of the door on the right hand side of the car a Green with Red wire (actually two wires into one) and a green wire are sticking out ... what do these connect to please? I am guessing these are for the reverse light switch on the gearbox ... but may be wrong. Does someone have a photo please of this switch and its location?
Where are the horns supposed to mount?
Paul
Paul
Have a look here for wiring colours: -
Vehicle Wiring Colour Code
Unfortunately, there seem to be very few forum members with the early XK sports cars.
Horns will probably be behind the front bumper somewhere.
Don't know about the rest, but if you post a couple of pics you might prompt a response.
Received 9,006 Likes
![Name: car01.jpg
Size: 19.3 KB](https://www.jaguarforums.com/forum/attachments/xk120-xk140-xk150-60/159760d1501264242-rewiring-xk-150-car01.jpg)
unsure if you have this info or if its helpful to you or not?
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
http://www.captainjaguarscathouse.co...ec%20Guide.pdf
I saw ths on google search: Jaguar World Magazine on XK 150 Restoration | Jaguar World
I also google searched using the words: Jaguar XK150 restoration pictures.
[Hey Paul,just started a restoration for a customer,removing all old wiring harnesses.The relay is next to the fuse box,between the voltage reg.and the hood hindge is a stud,thats where it mounts.Hope this is helpful. QUOTE=Paulrb;598171]I am trying to rewire an early XK 150 FHC USA model.
Paul[/QUOTE]
Paul[/QUOTE]
The turn signal relay is in a rectangular black box on the left wing. I found it very tight getting the new wiring harness to reach but ultimately got it done.
I think a previous post is confusing the relay with the flasher unit. What is on a stud on the firewall between the fuse box and the hinge is the flasher unit.
If you are doing an early 150, I strongly recommend abandoning the archaic turn signal lever under the dash panel and installing a later 150 turn signal on the steering column. It takes some additional wiring but is very simple. The early lever is useless. I converted the location of the old turn signal into a battery disconnect and had a machine shop mate the old turn signal handle to the battery disconnect switch. Of course this also required some additional battery cables, but not a big deal. Naturally, if you are going for a 100 point restoration, disregard this entire paragraph.
I might be able to get you pictures. My car is complete and accurate with regard to the relay and flasher. However, I am not very computer savvy so it might take a day or so.
I can probably answer some of your questions about the holes and wire routing, but thought I would see if this is of any help to you first.
Paul,
The oblong hole in the firewall is for the tach cable that runs off a right angle gearbox on the rear of the intake camshaft. The oblong shape is to accomodate the curve in the thick, stiff cable as it turns in towards the tach.
The horns mount on two of the four supports that support the front bumper, these two being identified in the Spare Parts Catalogue as the "Outrigger Brackets". You should find two holes in each one of them for the mounting bolts.
I forgot your other questions. Let me know what else you needed. I can send pictures from my iPhone to whatever address you want to use. I don't know how to upload pictures to a Reply.
baskervillema
10-01-2015 06:43 PM
PinnacleWax
Detailing / Car care
09-16-2015 10:28 AM
jagent
09-12-2015 01:40 AM
