XK120
Does yours still have the two 6 volt batteries fitted ? Most people convert to a modern compact 12v battery that fits one of the holders. I can't tell you what size is available, sorry.
You can still get the original 6v type as well.
https://www.scparts.co.uk/sc_en/brit...-fittings.html
XK120 Batteries
I don’t have batteries at the moment. Every 10 years or so I replace all the fluids and drive for about 10 miles or so. The batteries used to die quickly even later when I used a battery maintainer.
So looking for a more modern battery; either 2 six volts or 1 or 2 12 volts that fit in the boxes.
Car info: 43K miles about 98% untouched. 8:1 compression motor.
