XK120 Brake Master Cylinder
There is indeed, and in the US too !
Welsh Enterprises, Inc - Jaguar XK120 Brakes Brake Controls Parts
tandem brake master cyl
While other fitments can be made..the tandem mcyl once set up correctly works well without problems. The usual problems are in rebuilds where the seals are damaged as they are pushed in past the protruding lower edges of the tilt valves. Jag wrote a service bulletin about this,. The other issue is exhaust heat to the mcyl fluid. A heat shield is advised and available (from Basset). Once done..no worries, works well. Rebuild kits are available. Hang on to any original tandem Mcyl..many replacments that are not orig are inferior. Better to always rebuild an orig.
KarimPA
09-12-2015 09:15 AM
1964Daimler
09-09-2015 12:28 PM
