XK140 Overdrive
XK140 Overdrive
Hello Everybody,
Well, the overdrive on my gearbox isn't working. I've just purchased my Jag, and knew the overdrive wasn't working before I bought it. The light inside the switch on the dash comes on, and I've confirmed the solenoid is functioning. But still no overdrive.
I know my car was sitting most of the last 2 years. I've spoken to the mechanic who worked on it for the guy I bought it from, and he said the overdrive was working about 2 years ago, but not for the last 6 months or so.
Anyone have any ideas I can try, short of pulling the engine and drivetrain?
Also, if it comes to an overhaul of the overdrive, anyone have a recommendation as to who can do that?
Thanks.
Borron
Thanks.
Borron
Hi Dennis,
I never did get the overdrive working, so, I pulled the engine, along with the transmission and overdrive, since that is the only way to get the overdrive out of the car. I then sent the overdrive to XKs Unlimited who had it overhauled for me. They told me that my overdrive was just worn out from years of use. Wish I had a better or easier answer for you. Good luck!
Best,
Borron
Best,
Borron
Hi Dennis,
The cost to me for the rebuild was $1,200 and I bought the cam (CO-5982) on top of that. This was a few years ago, so, I suggest if you're considering this alternative that you reach out to Don Green at XKs Unlimited for more current information. Good luck!!
Best,
Borron
Best,
Borron
Best,
Dennis
BrentGardner
28
04-26-2024 03:08 AM
yarpos
08-28-2015 05:53 PM
