XK150 seatbelts
Hello Gerry
I was faced with exactly the same issue when I fitted belts to my XK150 FHC recently. In my case they were inertia reel seatbelts, but the issues were the same, including no instructions supplied. Other than making sure they are attached to good solid rust-free steel, the main point is that the highest fitting wants to be pretty well at the same height as the top of your shoulder. Removing the trim from below the rear windows revealed a suitable point to drill through, with access for the fixing plate and nut through an existing aperture.
You can get a good idea using the examples here
Seat Belt Gallery | Jaguar Seat Belts – Quick Fit SBS Ltd
That's how I worked out what to do, but please let me know if you'd like me to take some pictures.
Hope this helps
Tony
Hope this helps
Tony
Hello Gerry,
No, I used the existing rear-most seat runner attachment holes, with suitably long and stong bolts to go through the seat runner (the part attached to the floor, not the part that moves with the seat), through the seat-belt mount, through the floor, and on through the seat-belt fixing plate (supplied with the seat beltkit).
Tony
Tony
FS[SouthWest]: Set 20" Kasuga Wheels
HJ808
06-24-2016 11:54 AM
Hafrod
05-07-2016 02:04 PM
Ragn0r
04-13-2016 12:07 PM
