$22 tps pigtail does fit ! Save$$$
Well , I promised you guys to let you know if the $22 Toyota TPS Pigtail fits, and yes it does and PERFECT !
Toyota TPS Sensor Repair Connector Throttle Position Connector Pigtail | eBay
Don't pay $200+ for a used pigtail, these are only $22+brand new, stronger than OEM and wire thickness IS THE SAME AS OEM.
Here is the plug installed on a brand new $45 XK8/XKR tps as mentioned in a previous post.It includes more than enough wire you will ever need
,just push it, it locks, clicks and everything,very firm fit, perfect connection! High quality pins!
![](http://www.supermotors.net/getfile/1044627/fullsize/tps-4.jpg)
Happy Holidays!Notes
Important part detailsYearMakeModelTrimEngineGenuine Intermotor Q...1998ToyotaCelicaGT Convertible 2-Door2.2L 2164CC l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1998ToyotaCelicaGT Coupe 2-Door2.2L 2164CC l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1998ToyotaCelicaGT Hatchback 2-Door2.2L 2164CC l4 GAS DOHC Naturally AspiratedTo 09/97; Genuine In...1998ToyotaSupraBase Hatchback 2-Door3.0L 2997CC l6 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997GeoPrizmBase Sedan 4-Door1.6L 1588CC 98Cu. In. l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997GeoPrizmLSi Sedan 4-Door1.6L 1588CC 98Cu. In. l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997GeoPrizmLSi Sedan 4-Door1.8L 1788CC 110Cu. In. l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997LexusGS300Base Sedan 4-Door3.0L 2997CC l6 GAS DOHC Naturally AspiratedFor Electronic Fuel ...1997LexusLS400Base Sedan 4-Door4.0L 3969CC V8 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997LexusLX450Base Sport Utility 4-Door4.5L 4477CC l6 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997LexusSC300Base Coupe 2-Door3.0L 2997CC l6 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997ToyotaCelicaGT Convertible 2-Door2.2L 2164CC l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997ToyotaCelicaGT Hatchback 2-Door2.2L 2164CC l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997ToyotaCelicaST Coupe 2-Door1.8L 1762CC l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997ToyotaCelicaST Hatchback 2-Door1.8L 1762CC l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997ToyotaCorollaBase Sedan 4-Door1.6L 1587CC l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997ToyotaCorollaCE Sedan 4-Door1.6L 1587CC l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997ToyotaCorollaCE Sedan 4-Door1.8L 1762CC l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997ToyotaCorollaDX Sedan 4-Door1.6L 1587CC l4 GAS DOHC Naturally AspiratedGenuine Intermotor Q...1997ToyotaCorollaDX Sedan 4-Door1.8L 1762CC l4 GAS DOHC Naturally Aspirated Page 1 of 10 previous page 1 2 3 4 5 6 7 8 9 10 Next page
Portions of the information contained in this table have been provided by dieseltruckpartsdirect
Item specifics
Condition: New Manufacturer Part Number: RPCTH151
Other Part Numbers: 1985003011, 89452-06010, 89452-12050, 89452-22090 Interchange Part Number: 213-446, 213930 Warranty: Yes Other Part Number: 89452-33010, 94853125 Country/Region of Manufacture: Japan Brand: Standard Motor Products
![Icon Smallest](https://www.jaguarforums.com/forum/images/smilies/icon_smallest.gif)
Item specifics
The following 7 users liked this post by aode06:
Cambo (12-25-2014),
cjd777 (12-25-2014),
Jumpin' Jag Flash (09-10-2015),
motorcarman (12-25-2014),
RJ237 (12-25-2014),
and 2 others liked this post.
We all thank you for your work in trying to save us a large amount of time and money.
If this will as a whole, (TPS and connector), work, surely we all need to put one on the shelf before things disappear.
I did notice the Ebay add said no longer available and there was a problem with someone suing, lets hope that's not going to happen. What about all the parts for MG and Triumphs being reproduced, the courts couldn't handle the suits.
Just thankful you are on to something,, even the plug is a big plus.
Have a good Holiday and don't worry about all of us setting here waiting to see if it all works!!LOL
Wayne
Wayne
lol well you cant sue a guy because a Jaguar guy decided to use a toyota tps connector LOL, and neither will the tps law suit go through, because the origin is outside the USA, so we lack jurisdiction here lol.
But hey, everyone is closed, i cant seem to find that security torx for my tps removal, but at least we know that connector fits and is higher quality than stock.
Can you confirm that this part relates to this repair?
JagRepair.com - Jaguar Repair Information Resource
Received 2,193 Likes
jimborino (02-19-2023)
sorry if the previous link did not work.
There are plenty of these on ebay and amazon and other parts stores.
![](https://www.supermotors.net/getfile/1044627/fullsize/tps-4.jpg)
I cant believe folks are selling us this tps pigtailfor such a high price and then want to turn around and try to sue someone for doing whats right lol
![Icon Roflmao](https://www.jaguarforums.com/forum/images/smilies/icon_roflmao.gif)
DON'T WORRY
If your two wire is disintegrated, simply remove the pins from the connectors or destroy them, solder and heatshrink these two guys in or a different universal two wire pigtail, male and female, then plug together : ),these can carry up to 18volts!!! and others even more, so don't worry.
![](http://thumbs2.ebaystatic.com/d/l225/pict/390529497913_3.jpg)
![Icon Pala](https://www.jaguarforums.com/forum/images/smilies/icon_pala.gif)
you can get em at radioshack or any hobby store or online for under $10
cjd777 (12-29-2014)
It took me forever to find the right label and replacement for that. Found it on rock auto for $27 plus shipping. Air intake/charge temperature sensor connector
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/920x2000/screenshot_20230219_075115_chrome_7416fafe184765fc9fb634ab0c50fe25074693b0.jpg)
aholbro1
08-05-2021 05:02 AM
xjrjag
09-27-2015 01:53 AM
