2001 XK8 4.0 NA Oil in the Spark Plug Wells
The mother in laws Jag developed a bad miss the other day with a CEL. Going through the codes it looks like a miss fire. Since these were the original plugs I started with them. To my surprise there was a considerable amount of oil in the spark plug wells. Is this from a leaky valve cover gasket?
Thanks, in advance!
Thanks, in advance!
Thanks, in advance!
Thanks, in advance!
The gasket set FEL-PRO Part # VS50724R or
VICTOR REINZ Part # VS50397 includes all necessary seals.
ericrucker (09-19-2023)
One side done and new battery installed. Now I'm getting an ABS failure as well as :
P0357 - Ignition Coil G Primary / Secondary Circuit
P1000 - ODB System not ready (if I remember correctly)
P1649 - FCCP Monitoring Flash Memory Malfunction
I was getting a miss in cylinder 6 and swapped coils with cylinder 7. Initially it ran fine but shortly developed a miss.
Sounds like I need at least one new coil. Are the Denso coils significantly better than what I can get at the local parts store?
Charlene n John
09-28-2015 06:01 AM
