2005 tail lights in my 1997 xk8
Old 06-15-2011, 05:52 AM
andrezbim's Avatar
Originally Posted by XKRacer
Fitting the original light back in would be quite simple, I dread to think when they see what I have done
Not so simple when you cut a hole like this.....
I LOVE IT!
I will do this mod on my next one!
Old 06-15-2011, 03:59 PM
xenophobe's Avatar
Originally Posted by andrezbim
After lots of cutting, voila!
That really reminds me one of the reasons why I wanted the 05. My 97 is nice and classy, but the 05, for not having so many changes, looks so much nicer.
Good job! If this weren't an expensive mod, I'd do it to my 97 too.
Old 04-05-2012, 01:46 PM
97xk8dee's Avatar
Default 97xk8dee
hey was thinking about 05 taillight conv... is cutting that has to be done inside so lights will go in? is there any cutting that needs to be done on outside body?
Old 04-05-2012, 01:48 PM
XKRacer's Avatar
No cutting outside the shape is the same, you just need to allow the depth of the light unit, you then need to fix them in place and change the wiring
andrezbim's Avatar
NO... definitely no.
Old 04-05-2012, 01:49 PM
97xk8dee's Avatar
Default 97xk8dee
Old 08-26-2013, 04:33 PM
Mwise34's Avatar
Literally a hole the size of the tail light.
The jewel tail lights mount quite differently to the body.
Yours screw to the body, while the newer version protrude through the hole that the old would have screwed to, and have a bracket of sorts from the back side.. like a drywall screw approach.
Really freshens up the look i think... although subtle.
I made brackets out of aluminum, but i think they can be sourced directly from Jag.
Would you be willing to make me a set of brackets? For a fee of course.
  #28
Old 08-26-2013, 04:57 PM
giandanielxk8's Avatar
Received 1,433 Likes on 767 Posts
I have to wonder, is it not at all possible to just swap the outer lens of the tail lights and not having to cut holes into the body? Maybe roast them in an oven until you can separate the lens from the assembly and swap?
Old 08-26-2013, 06:49 PM
The Coupe's Avatar
Contact Tony (known on this forum as XKRacer), at Paragon Design UK. He makes his own brackets for this conversion and they are much less expensive than anything you'll get from Jaguar. He's a top-notch guy, too.
Paragon Design UK
XKRacer (08-28-2013)
  #30
Old 08-26-2013, 08:18 PM
Windycityx's Avatar
Is there a how to video on this?
  #31
Old 08-27-2013, 03:26 AM
Mwise34's Avatar
Talking
It sounds feasible, but we need someone to be a pioneer. Doing it this way would save me a lot of time and at least $200.00.
  #32
Old 08-27-2013, 09:29 AM
I'm assuming the $200 is spent on cutting up the holes?
  #33
Old 08-27-2013, 09:57 AM
Bad Cattitude's Avatar
I think that is the cost of the replacement brackets.
  #34
Old 08-27-2013, 10:06 AM
The Coupe's Avatar
As an FYI, here are the instructions provided by Paragon Design UK for this conversion. Tony is very helpful, although as a general rule, you shouldn't clog his email unless you're buying products from him.
Attached below as a PDF.
  #35
Old 08-27-2013, 01:42 PM
Mwise34's Avatar
Thumbs up
Bingo
  #36
Old 08-27-2013, 06:56 PM
BurgXK8's Avatar
That does look a lot better. I knew there was something about the look of the 2003 compared to the 1997 I used to have. That and the much better headlights.
  #37
Old 08-28-2013, 09:32 AM
XKRacer's Avatar
You can not separate the lenses as they are ultra sonically glued together.... basically melted.....
I have seen situations where people have siliconed the units in place... very messy and nasty.
Nothing beats using the correct items but when they are costly or unavailable, needs must..... The panels I supply do the job very well and look as close to stock as you can get and cost half the price of OE..... The choice is yours at the end of the day but I know for my money I would want the job to look right rather than a bodge
  #38
Old 10-16-2013, 05:22 PM
Mwise34's Avatar
Is the wiring the same for 2000 xk8 as the 97-99? The reason I am asking because my wires are a completed different color than the ones in tony diagram.
  #39
Old 10-16-2013, 05:34 PM
XKRacer's Avatar
Yes Jaguar did change them... You have more orange wires.... I can put them up tomorrow when I am back at work
  #40
Old 10-16-2013, 07:19 PM
Mwise34's Avatar
Thumbs up
Thank you.
Quick Reply: 2005 tail lights in my 1997 xk8
