An alternative to 96 to 2001 Fog Lights
I did this a while back..... I fitted 2006 X150 XK fog lights to an earlier X100, the benefit of this is the availability and cheapness of a more generic light, these type of units are used by many manufacturers including Peugeot, Vauxhall and Citroen and of course Jaguar on the XK, XJ and X types.
Also there are various styles, as fitted here a set with LEDs not necessarily to my taste but the customer was very happy.
All you need to make up is a couple of simple aluminium brackets, works well, wiring is no problem you can easily get the correct plug from a breaker or use a couple of small spade connectors
K.Westra (09-18-2012)
I wouldn't have thought that LEDS would have anything like the same lumen output of the original fogs...the replacements are more like DTRL's.
As to aesthetics I think it's very colour dependant, for example they may look poor on carnival red but would I think look good on black/silver/antigua.
XKRacer are those really X150 standard fitment, if not what did you actually use?
What diameter or part number can we use to find these?
rsa760041
23
09-25-2015 01:33 PM
