Battery vent tube.
Yes, you should supply a Vent Tube from the Battery to the Hole and it should extend down through the grommet 8" or so.
hlgeorge (06-13-2011)
This is the kind of thing we can get away with 99 times out of 100, but that 1% can be a real b**ch. Ka-boom!
So, if running without a vent tube, until that's fixed what conditions would make a lot of hydrogen and so create a danger? There are two I can think of:
- an unusually high reading on the voltmeter would indicate an overcharging condition. That can make a lot of hydrogen.
- if the battery has been fully dscharged or close to it, it will be recharging very rapidly even with a normal voltage reading. That could be trouble too.
FWIW ...
FWIW ...
Battery - Page 2 - Jaguar Forums - Jaguar Enthusiasts Forum
I just bought some clear vinyl tubing from Home Depot. I'll install it tomorrow and take a pic to post.
A few minutes later: OK as I was typing the above, I got an itch that really needed scratching. I had to go and put the vent tube on. A few minutes later and I am back to report success on this easiest project I have ever done to my car. 10 minutes tops!!
Very nice, Lew. And with clear tubing, you can watch those little H2 molecules going by.
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Would it be worth posting the tube diameter? With a little luck, there might be a standard size among the various battery makers. Not sure about this though.
I've been following the battery vent thread but I don't think anyone has mentioned that on batteries with two vent holes, one hole needs to be plugged (my Autozone battery came with a plug for this purpose molded into the positive terminal cover flap) while the other one goes to the vent tube. Comments?
The plug is supposed to be molded into the positive terminal protector. You snap it off and insert into the unused vent hole.
There is a BMW battery vent elbow that fits perfectly. It also fits the stock vent hose on a X308 perfectly.
The hose is 3/16-7/32 inside diameter.
https://www.jaguarforums.com/forum/j...ttery+shortcut
Old thread, but I am fixing mine tomorrow. I just installed a new Interstate and did not connect a tube. The old battery did not have one connected. Interstate has kits for about $5. Thanks for this thread.
