Brake Pedal Feedback
Upon various pedal effort I will at times get a very mechanical feeling feedback throught the brake pedal, a "clunky" feel, not a pulse like a normal ABS system in slippery conditions more like a brief shudder that effects pedal travel. It is very inconsistent, braking power is not reduced and it is not pulling to either side.
It has been happening sporadically for a while before and after a recent rotor and pad change. I am not an expert but I am thinking this is related to either a sticking caliper and the brake booster over compensating or a faulty/ ailing brake booster.
I know I mentioned it is not pulling which may eliminate the sticking caliper but I do have 4 piston Brembos, so my thought is if one piston momentarily sticks the brake will still operate enough not to notice a pull to one side or the other.
I could be completely off target but I am curious if anyone else has experienced this or can lead me in the right direction.
I will take a closer look, or feel, next time the car is out but casually there appears to be no noticeable heat variation.
I can say there is no difference on the surface/wear pattern of the rotors, if that means anything.
Good point but it usually happens under light braking/light pedal effort. It certainly feels mechanical rather than a hydraulic shudder, almost like there is some type of linkage issue. The only linkage I am aware of is the pedal assembly and the booster to the master cylinder.
![Brake Pedal Feedback-brembo-guide-pin.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/36051d1480967897t-brake-pedal-feedback-brembo-guide-pin.jpg)
Any high spots or corrosion and the pads can bind on them.
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
It appears this was caused by the wiring harnesses that are zip tied to the upper control arms. Someone has mentioned this before but I was pretty skeptical as my car was giving me intermittent DSC system faults, the ABS light and apparently the related issue of clunky brake pedal feedback. After a lot of cleaning of the sensors, connectors and inspecting the modules I looked at the wiring harnesses as a last resort prior to repacing components. It worked, as I was finally able to cure all the above issues by simply removing the zip ties, adding slack and re-tying them.
ericjansen
12-19-2021 12:20 AM
