Can the back windows be rolled up with the top down?
Old 06-09-2010, 07:46 PM
Reverend Sam's Avatar
Received 1,261 Likes on 565 Posts
Default Can the back windows be rolled up with the top down?
My wife likes the windows to be rolled up even with the top down. Is it possible to roll up the back windows, too? I just installed a wind deflector, and I'm thinking that with all four windows rolled up my wife's hair should stay put even without a scarf.
If it isn't something that the car does by default, have any of the experts on here rigged a way to roll up the windows with the top down?
UPDATE!
For new members who haven't followed this thread for nine months, if you fast forward to post #32 you'll see that I finally got the back windows to work independently of the convertible top. It's not that difficult to do if you know how to use strippers (NO! Not that kind!) and and crimpers. I'm going to write up the instructions on how to do it. I promise it won't take me nine more months.
UPDATE #2!
If you go to post #51 you'll see a video of how to raise the windows with the top down.
UPDATE #3!
If you go to post #107 you'll see how to installed some relays that allow you to control the rear windows with the same button that controls the convertible top.
The following 3 users liked this post by Reverend Sam:
Doctodd (02-26-2021), Marsden (05-27-2011), Orthodixie (05-27-2017)
Old 06-09-2010, 07:57 PM
alfred's Avatar
Does not happen. Back windows roll up as the last of the top closing sequence. Buy her a hat.
Old 06-09-2010, 08:07 PM
OK then, it's just a power window. There has to be some way to add a momentary toggle switch somewhere to force them up. I'd just have to remember to force them down again before putting up the top.
Old 06-09-2010, 08:18 PM
Kevin D's Avatar
Sometimes, wives ask for too much. I suspect that Gus is going to come on here and tell you that the whole roof opening and closing system is a very complex sequence of events, that you may better off not tampering with.
Old 06-09-2010, 08:20 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
Simple electrical/mechancial solution associated with the relays that operate the rear windows. On my first car with a serious hydraulic problem, I took the covers off the relays and drilled an 1/8" hole in the appropriate place to allow a plastic/wood device (toothpick) to manually operate the relays. You could wire the relays into a switch but for the occasional use a toothpick may be all you need.
Old 06-10-2010, 07:08 PM
hlgeorge's Avatar
Glad I don't have a wife!
Old 06-10-2010, 07:22 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
Old 06-10-2010, 08:58 PM
Which relays and where are they located?
Old 06-10-2010, 10:30 PM
H20boy's Avatar
Sam, one of these days, you're gonna break somethin...
Old 06-10-2010, 11:26 PM
Oh... I've already done that. My windshield had a chip which I think I talked about in another thread. Since the glass guy couldn't fix it I thought I'd try it on my own. I fixed the star fracture, but in the process I put a three inch crack in the windshield. It's barely noticeable, though. It's not nearly as bad as the star fracture was.
My background is electronics, though. I figure I can rig a switch, I just need a wiring diagram, and I need to know the location of stuff.
Old 06-10-2010, 11:30 PM
By the way, I really wish I could roll those windows up right now. I tinted the front windows this evening because I couldn't figure out how to get the back of the seat open to fix the head rest (that's my next thread). The back windows are going to be a bitch because I can only tint them with the top up.
And don't worry, I didn't do one of those ghetto, 95% black tint-jobs. I just did a light tint in the hope that it will keep the inside of the car a little cooler on our western tour this summer.
Old 06-10-2010, 11:52 PM
H20boy's Avatar
Sam, just PM me your home email, I'll send you the whole electrical PDF for our car. You don't have Email turned on in your profile settings. Its directly from the JTIS, and very thorough.
Old 06-10-2010, 11:55 PM
I'm burning the JTIS to CD as I type this. If that doesn't work I'll have you send it to me. Thanks.
Old 06-11-2010, 09:01 AM
The JTIS CDs have a virus.
Old 06-11-2010, 09:06 AM
I could show you some videos that would make you think otherwise... Nothing's better than cruising down the highway with the top down while... well, nevermind.
Old 06-11-2010, 10:10 AM
test point's Avatar
You need the JTIS if you are going to continue to break things anyway. The link to Gus's site with the electrical schematics is near the bottom of the XK8/R FAQ sticky. It has all the relay layouts.
Old 06-11-2010, 10:32 AM
H20boy's Avatar
More than likely, you gave the CD one. You are referring to the download on the mediashare site?
Grab the zip file instead, mine went off w/o a hitch.
Old 06-11-2010, 11:31 AM
I said "damn the virus, full speed ahead" and installed it anyway. I figured out which relays I need to control. Now I just need to figure out where all of the wiring runs. It looks like it should be pretty simple. I just need to put voltage on one wire to roll both windows down, and another wire to roll them both up.
Old 03-26-2011, 12:56 PM
silverstone's Avatar
Reverend,
Did you ever figure out how to do this?
Been wanting to do it myself.
Let us all know if there is a video I missed!!!
Old 03-26-2011, 04:53 PM
I never did it, although just last week I was thinking about it again. I bought a three position momentary rocker switch which I was going to install in the compartment below the arm rest. There are two wires that run through the space under the center arm rest. When you apply voltage to one the windows go up, apply voltage to the other and the windows go down. That would be a fun little project to do this weekend.
Toppntch (01-30-2013)
Quick Reply: Can the back windows be rolled up with the top down?
