.....................carbon dynamic air induction jaguar xkr
User 070620 (01-14-2013)
User 070620 (02-26-2014)
I was not totally kidding! I know that the pictures are in the XKR with aluminum frame, but it could be a good idea to make a similar filter in carbon and have a bonnet cut to create the space needed, making a air dynamic as this....
Maybe they choose this way as easiest setup, and there is probably also some ram air openings in the bumper, but that just as well can be done with the single air tube on the steel bodied cars.
I was hoping to see one this month, but as it looks now, it may be next month (not under my control...).
In case someone wants to know what it’s about, see the attachment. This one is made by TLJaguar in the UK especially for the twin-screw kit, and they can be reproduced.
User 070620 (01-18-2018)
the question I posed is that normally the suction tube passes over the exhaust manifolds by heating the inlet air to the engine. In addition, with a central air intake dynamic, we have a natural extra pressure in the compressor with the increase of speed.
is for this reason that the jaguar racing Ferlito using dynamic central air vents for their race s-type and XF cars!
I think there is a reason!
This is my 90mm induction set up.... still needs dressing and a good polish but you get the idea..... I have had to remove a small piece of the bonnet/hood frame for clearance, nothing drastic
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/30298-carbon-dynamic-air-induction-jaguar-xkr-induct2.jpg?dateline=1358246233)
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/30299-carbon-dynamic-air-induction-jaguar-xkr-induct1.jpg?dateline=1358246233)
I am designing a special type of cold air feed using liquid CO2, this runs at -80 and the air passes over it should cool down alot.... in theory 20BHP gains maybe possible but we shall see the good thing is it will work on XK8s as well as Rs
You do need to fit some good shielding to protect the pipe from the manifold and cat giving off heat but that is not difficult...
The Coupe (01-15-2013)
It’s one of the reasons I keep much silicon piping (support by an inner aluminum pipe) instead of aluminum as it gives a little extra isolation.
However I personally think the gains of isolating the tube are very little(/neglectable), at full throttle for a stock car (with a 85mm id intake tube) the air is moving (if my calculations are right) at about 45 meter per second, so not much time for the air to pick up some radiated heat.
Also it’s only when you are standing still you get excessive heat form the manifolds/cats that heats up the piping, but much less when moving.
User 070620 (02-01-2013)
BrentGardner
28
04-26-2024 03:08 AM
FS[NorthEast]: Jaguar XKR Wheels for Sale
Griffbritgreen
07-27-2016 05:43 AM
Series1fan
09-05-2015 08:02 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
