Coolant leak
That definitely appears to have been leaking past the cap seal from the way the top of the tank is stained.
Different tank on the SC but the NA usually splits on the bottom, presumably from the heat of the exhaust over time. If this is the cause, the SC tank is likely to fail in a similar location.
steveinfrance (07-22-2012)
I think I've sussed it.
The cap is (as one might imagine) quite ingenious.
The lower O ring in the pic seals to the lower part of the tank neck.
There's a tiny brass poppet valve. When it opens it lets the tank contents communicate with the slot above the O ring.
There's a second O ring up inside the cap so the slot is sealed into the part of the neck where the overflow pipe goes in.
The upper O ring on mine had given up its little rubbery ghost so a small amount of coolant seeps past it when the valve opens.
I've replaced it so - hopefully .....
Better eyesight than me!
The clamp should be OK as it's a 'Norma' pattern which is either open or closed (no adjustment) but the end of the hose could be shot.
I'll do the old central heating engineers trick + wrap some kitchen towel round it.
Even if the coolant evaporates it will still dye it.
The leak is tiny but I don't like it.
The header tank is always full - presumably coolant gets into the overflow tank when it gets hot and gets drawn back into the header tank as things cool down ?
I've had a similar experience over the last couple of weeks. I can smell coolant when I'm stopped at a stoplight or after I've stopped the car, however, there are no drips under the car. But, I have been adding about 2 cups of coolant per week or two. From the smell test, the odor is strongest at the front passenger side of the engine bay, maybe some seepage through a loose hose clamp or something. I'm going to pressure test tomorrow and see if we can locate. Smell and the fact that I know there is a small leak drives me nuts.
If i'm not mistaken (and as usual i probably am) a gite is a detached guest house.
A couple of years ago i was fantasizing of a house in France with it's own lake and seperate accomodation for visitors, which at the time could be bought for about the same as a 3 bedroom rabbit hutch in England.
Don't tell me you have a lake in the back garden as well?
![Icon Drool](https://www.jaguarforums.com/forum/images/smilies/icon_drool.gif)
Received 6,312 Likes
