Door Handle Rubber Gasket
My 2000 XK8 has suffered the effects of the sun. Both door handle rubber gaskets have deteriorated and parts of them have come off. I called the dealership and was told that the gasket can not be purchased without the entire door handle. The door handle is $761 EACH!!!! I chose not to spend $1522 for such a minor cosmetic problem. Has anyone tried to repair their broken door handle gaskets using Permatex? I'll take some pictures and post them later today.
You will need to purchase JLM-12035/kit. I found it at Coventrywest. The gaskets come in a kit (as the name implies) both right and left door, about $80. You need to remove the door handles and install the new gaskets. I posted a repair on this subject called "drivers door, outside handle removal"
The following 2 users liked this post by itspec60:
Dan R (11-21-2010),
rickjensen (11-09-2012)
Itspec did a good job with the instructions, but if someone wants to document the removal/reinstall with some visual aids (you got it...pics!) then add it here, or his other thread that he started. <- and FAQ'd for future use
1964Daimler
09-09-2015 11:28 AM
