Engine Serial Number Location
Old 03-26-2012, 06:03 PM
Jag69's Avatar
Default Engine Serial Number Location
I did a search of the forum and did not find anything so if the answer is out there I apologize...
Does anyone have a picture or diagram of where the engine serial number is located?
Thanks in advance!
reb1999 (05-16-2014)
Old 03-26-2012, 06:24 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
The easiest place to read the engine serial number is on the computer terminal at you local Jaguar dealer with the VIN as input. It is stamped on a milled area near the water pump but I defy you to read it.
The following 2 users liked this post by test point:
Don-T (05-02-2013), Jag69 (03-26-2012)
Old 03-26-2012, 07:04 PM
GGG is offline
Received 16,858 Likes on 12,186 Posts
Originally Posted by test point
..........I defy you to read it.
.........but if you're determined:
XK8 - Engine Number.pdf
Good luck!
Old 03-26-2012, 09:06 PM
test point's Avatar
Lol!
Old 03-26-2012, 09:45 PM
Received 8,131 Likes on 4,906 Posts
Early engines have it at the left front top of the block and the later engines are stamped on the left side near the engine mount bracket.
I don't remember when the location changed.
bob gauff
Doug
02-27-2019 01:31 AM
afterburner1
12-16-2015 12:12 AM
KarimPA
09-03-2015 07:32 PM
OkieTim
09-02-2015 12:48 PM
philwarner
09-02-2015 11:45 AM
Quick Reply: Engine Serial Number Location
