Engine woes - the journey begins
Old 03-23-2012 | 05:43 PM
dx3's Avatar
dx3
Default Engine woes - the journey begins
Folks,
I picked up a 97 XK with 115k miles. It had been parked about 8 months ago because the motor wasn't running properly (loss of power, rough idle, noises). The gentleman lived out in the boonies, so there were no local mechanics willing to work on it. Anyway, he put it up for sale and I made a 10 hour return drive to pick it up.
Here is a video of the engine, and no that isn't a compressor running in the background. Seems like there is, among other things, a vacuum leak.
79fbc256.mp4 video by drinkdontdrive - Photobucket
For some unknown reason, I started on the passenger side removing the valve cover. I was hoping it would be as clean as some of the other pictures I've seen on here... not so much. The one thing I can say is I know lubrication/oil flow isn't my problem...
I am familiar with Toyota's, but have never touched a Jag before. If anyone has any input, please feel free to chime in. Open forum:
I will update as I work on it.
Jonny
Old 03-23-2012 | 06:25 PM
Beep777's Avatar
Care to share what you paid for it? How does the rest of the car look?
Like you, I have turned wrenches on other types of cars, but a car is a car.
Read up, this forum is terrific. As knowledgeable as any there is, plus you don't have the 20 years olds sniping at each other saying their neon and coffee can exhausts are better than yours.
B
Old 03-23-2012 | 06:26 PM
Beav's Avatar
It has obviously jumped time, notice that the flats on the cams (just behind the first bearing caps) are not aligned.
The following 2 users liked this post by Beav:
dx3 (03-23-2012), parker98 (03-27-2012)
Old 03-23-2012 | 07:23 PM
test point's Avatar
You may have escaped with new tensioners, which should be replaced anyway, and associated alignment of cam timing. Sorta got to do that before you can determine if there is further damage associated with a piston and valve attempting to occupy the same space at the same time.
Good luck.
Old 03-23-2012 | 07:34 PM
dx3's Avatar
dx3
Thank you gentlemen. I hadn't noticed this so I appreciate you noticing it. I have a friend who is a little more familiar with this who will be coming over tomorrow to take a look.
Here is the drivers side - please let me know if you see anything here that I might not have:
Thanks again for your help - truly appreciated. Regards,
Jonny
Old 03-23-2012 | 10:15 PM
dx3's Avatar
dx3
Can anyone point me in the direction of a thread where I can find info on how to correctly time the engine in relation to cam orientation? Thanks for any and all help,
Jonny
Old 03-23-2012 | 10:22 PM
Abby's Guy's Avatar
Beav, that is exactly why so many of us are here. Guys like you just see a picture and already know more about what's going on than some of us do by standing there staring all day. Thank you (and those like you) for sharing so freely.
Old 03-23-2012 | 10:40 PM
Beav's Avatar
Hard to be certain by the pics but I'd guess one tooth off. Search 'tensioners' to find out all you never knew you wanted to know about Jaguar cam timing and how to rectify your problem.
Old 03-24-2012 | 05:05 AM
danand's Avatar
Jonny, your Left tensioner is missing it's shoe! The chain is riding on metal. I'll bet your Right one is in similar shape (the tensioner piston is on the bottom for the right side).
Dan
Old 03-24-2012 | 11:57 AM
2000CAXK8's Avatar
I am considering removing the valve covers to see if I have the old plastic timing chain tensioners, can anyone point out in the above pictures where you can see the tensioner?
A jag mech said you can see em from up top like this...
Old 03-24-2012 | 12:39 PM
Beav's Avatar
Post #5, first two pics. Directly behind the chains you see six bolts in a row, parallel to the chains. The two center bolts retain the problematic, secondary tensioners. *'behind' means between the camera and the chains as the front of the engine is at the top of the pictures.*
2000CAXK8 (03-24-2012)
Old 03-24-2012 | 02:18 PM
2000CAXK8's Avatar
Thanks Beav, so theres no way to see the long curvy primary chain tensioners from up above?
Old 03-24-2012 | 02:28 PM
2000CAXK8's Avatar
So for novices like me, these are the two parts to replace??
$95 x2= 190
JA-C2A-1512 - Chain Tensioner Revised Type, V-8, "B" Bank (+A bank one)
$32 x2= 64
JA-NCA1998AB - Chain Guide, V8 Lower
Old 03-24-2012 | 04:49 PM
Beav's Avatar
For my money (and especially since I'm an EVT where everything has to be 110% at any given moment) I can't recommend doing half of a job. What if you just couldn't see that one space where it might be broken, etc.? A lot of peeps only do the secondaries and if I told you that was fine and something happened down the road you'd be calling me every name in the book. So... ;-)
Old 03-26-2012 | 09:48 AM
dx3's Avatar
dx3
OK gentlemen, a status update. Upon further inspection of the passenger side I noticed this:
which turned out to be:
which led to:
(video link) a26ab5cf.mp4 video by drinkdontdrive - Photobucket
So is this part of my tensioner, part of the slider? I figured it was part of my tensioner. I also notived that the tensioner on my pass side is very different than the drivers side. At this point it looks like I will be replacing all tensioners just to be safe. Are there 1 or 2 tensioners per chain? So 4 tensioners total or 8?
Now to put together a parts list of what all I need to order.
Valve cover gaskets interchangeable with Lincoln LS? Tensioners? What about O Rings etc? Thanks gentlemen,
Jonny
Old 03-26-2012 | 10:13 AM
WhiteXKR's Avatar
On a '97 your can use the Ford/Lincoln tensioners, but you must use the Jaguar gaskets and O-rings.
Old 03-26-2012 | 10:35 AM
Gus's Avatar
Gus
It looks like you have a great project car full of opportunities.
Old 03-26-2012 | 11:56 AM
dx3's Avatar
dx3
Dan
Thank you both for your help - much appreciated
Gus - I hope so! Your website is wonderful and a huge help
Do you know which year Lincoln I order from by chance? Thank you
Jonny
Old 03-26-2012 | 12:08 PM
WhiteXKR's Avatar
Jonny
Ford Lincoln LS (3.9L) parts:
Ford PN 2W9Z6K254BA Right Secondary metal bodied Tensioner (1 required)
Ford PN 2W9Z6K254CA Left Secondary metal bodied Tensioner (1 required)
Ford PN W500301S300 Bolt (4 required)
I got good
pricing at http://www.sunroadfordparts.com. The Ford parts even said 'JAG' on the box.
dx3 (03-26-2012)
Old 03-27-2012 | 09:07 AM
dx3's Avatar
dx3
Well gentlemen, next course of action is to replace the top 2 tensioners and go from there. Can anyone tell me the cheapest place to locate the specialty tools I need? So far I have found this:
http://www.motorcarsltd.com/303-530.html
and this
http://www.motorcarsltd.com/jaguar/x...nsioning-tool/
Are these the 2 tools I need to replace just the tensioners up top (secondary)? I am not in a position to build my own, but would like to find the cheapest source and make sure I have everything I need to do the job without getting stuck for another week ordering a new part.
Thanks again,
Jonny
Quick Reply: Engine woes - the journey begins
