Front Brakes on 2001 XKR
I've done some searching on the forums about brakes and ASC/Traction Control repairs but have found little mention of costs involved. So I wanted to ask if the following is in line.
I took my 2001 XKR in to my Jaguar dealer for a routine oil change today. I have also been having the intermittent ASC/Traction Control unavailable issue and I knew that the front brake pads were getting low. So I had them check these items as well.
The quotes I got back for the front brakes only and the repair of the asc/traction control were quite high and was wondering what I should realistically expect for this service?
Front brakes, pads and rotors: $1700
ABS Control Unit: $2800
They said higher cost was due to my XKR having the Brembo brakes but don't they have the fancy bright red calipers that are usually indicative the the Brembo brakes, if so I don't have those. Is there a way to confirm I have those higher end brakes? From some searches here it seems that in 2001 only the silverstone and x100 xkr had them.
Are these costs in line?
I saw the excellent FAQ about cleaning the wheel speed sensors so that's my project for the weekend. I mentioned this to the service tech and he said unfortunately the code that came up usually means the control module is shot. Something about pump code.
piju1945 (10-19-2015)
They are in business to make money. Cleaning the sensors might not fix the traction/ABS issue, but it's free to try it and it might save you $2800. The brake pads and rotors can be done much cheaper than that. Here's a complete set of drilled and slotted rotors plus ceramic pads on eBay for $480.
http://cgi.ebay.com/ebaymotors/XK8-X...ht_3182wt_1167
That's FOUR rotors and FOUR sets of pads for under $500.
Changing the pads and rotors is an easy do-it-yourself job. Even if you're never done it before you can probably do both sides in under three hours. Just make sure you have the right tools to start with. Running back and forth to the hardware store/parts store eats up time. If you need some instructions on how to change pads I can easily take some pics and show you how easy it is. I'm no expert, but I bet I can jack up the car, remove the wheel, remove the caliper, replace the pads, reinstall the caliper, and reinstall the wheel in 20 minutes.
Also, why are they telling you that the rotors need replaced? How many miles are on the car? They might just be trying to add to their bill.
If you have the Brembo fixed calipers as opposed to the floating calipers then the brake pads/ rotors are quite pricey. As for the module, if you are getting C1095 pump motor code then cleaning wss won't help. There is a solder joint in the module that fractures causing this problem. We fix these ourselves at our shop.
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Beauregard, unfortunately it looks like you were correct about the wheel speed sensors.
Here they are front and back after being cleaned:
![](http://creativebush.com/jaguar/brakes/FrontSpeedSensorsClean.jpg)
![](http://creativebush.com/jaguar/brakes/RearSpeedSensorsClean.jpg)
When I started up the car the warning was not on, great I thought. Well I pulled out of the driveway and boom the warning popped up about ASC/Traction Control unavailable with the ABS light also lit up. :-(
Once I saw that they were magnetic sensors I didn't hold out much hope as it would probably take a some type of metallic filled gunk to really affect them in any way. Or if they were detached or broken some how. But it was definitely worth a shot.
I saw a thread on removing the ABS control module and opening it up to repair the solder joint. It looked a little involved though.
Next up are my front brakes. Several people on here mention it is a relatively easy job and if I could save myself $1700, I'm willing to give it a go. Problem is, I still can't seem to determine what type of brakes I have, are they Brembo? They sure don't look fancy like they are but admittedly I'm no expert. Can anyone tell from the following photos?
![](http://creativebush.com/jaguar/brakes/FrontDriverSideBrakes.jpg)
![](http://creativebush.com/jaguar/brakes/FrontDriverSideBrakes2.jpg)
![](http://creativebush.com/jaguar/brakes/FrontDriverSideCaliper.jpg)
![](http://creativebush.com/jaguar/brakes/FrontDriverSideBrakes3.jpg)
Any help identifying what I need for rotor and pad replacements would be greatly appreciated.
Yep, I agree. Definitely need pads and rotors.
Thank you all you've been extremely helpful, I'm getting all teary-eyed :-)
This is an easy do-it-yourself job, now. Just make sure you have the correct brake caliper torx bit to remove the calipers. I forget what size it is, but Advance Auto Parts sells a little set of five torx bits specifically for removing brake calipers. The set is only $8 or $10. I bought one a couple of weeks ago.
You might have a little trouble getting the calipers off since the lip on the edge of the rotor is so high. Maybe someone else has a tip on how to open up the calipers prior to removing them.
I don't know if it's fixed yet but special thanks go to Gus for pointing out this fine tutorial by Dan Jensen:
http://www.jag-lovers.org/snaps/snap...?id=1230845126
Here's what I've done thus far:
Successfully removed the control unit
![](http://creativebush.com/jaguar/ABSControlUnit/ControlUnitRemoved.jpg)
Control Unit Opened
![](http://creativebush.com/jaguar/ABSControlUnit/ControlUnitOpen.jpg)
Sure enough, broken solder joints
![](http://creativebush.com/jaguar/ABSControlUnit/BrokenSolderJoints.jpg)
Repaired solder joints - I hope![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
![](http://creativebush.com/jaguar/ABSControlUnit/FixedSolderJoints.jpg)
Getting ready to apply RTV and close up unit
![](http://creativebush.com/jaguar/ABSControlUnit/ClosingControlUnit.jpg)
Now I'm just waiting for the RTV to cure before I put it back into my car.
Given that I did have broken solder joints I'm relatively confident this will fix my ABS/Traction Control/Stability Control Unavailable issue. I have my fingers crossed!
Control Unit Opened
femacon (10-04-2017)
I was pretty consistently getting the traction control/ ABS fault, good news... I put everything back together this evening and test drove it a couple of times and didn't get the warning! Woohoo!
Still have my fingers crossed though
thanks for crossing yours in solidarity Matt ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Rev, I'm still a little nervous about replacing the brakes myself... I did find a local independent Jaguar mechanic though, going to try and meet with them this week.
if you can remove, repair and reinstall the ABS module, you can do brakes Paul. Its literally that outside clip, two caliper pins, the caliper bracket bolts and beating the rotor to come off the hub (if she's really rusted on) Same with the caliper bracket bolts, first time I broke 'em loose, they were really on there. Rubber mallet and a wrench, your best friends. Install is much easier.
Anyway, just in case, there's some words of encouragement!
mmadison (11-30-2013)
