Front Suspension Bushings
Old 09-02-2013, 06:56 PM
giandanielxk8's Avatar
Received 1,438 Likes on 770 Posts
Default Front Suspension Bushings
Anyone know the part number? How much should I expect to pay for them?
My gramps found me a mechanic that will do the work for $40 a bushing. Sounds like a good deal to me. I just need to provide the parts.
Old 09-02-2013, 07:43 PM
ccfulton's Avatar
Received 1,108 Likes on 764 Posts
Which bushings are you meaning? If you do all of them, it can get a little pricey, plus it requires an alignment be done.
I did the front of mine with poly bushes and just bit the bullet and did them all at once rather than piecemeal:
PowerflexUSA - XK8 - XK8R (97+)
If you are going to start into it, check the upper shock mounts too. They aren't cheap, but it might save you paying the same labor again some time later, since most of the work to get them out is the same as the bushes.
Old 09-02-2013, 08:03 PM
I'm guessing, just the lower ones for now. I need an alignment anyways.
Here's a picture of the problem, maybe it'll help.
Old 09-03-2013, 07:52 PM
Help, this is the bushing that's closest to the oil filter. I'd be chancing that one and the one on the opposite side. I would appreciate the parts number.
What are the advantages of the poly bushings? Is that part in my picture a bushing or is it something else?
Old 09-03-2013, 09:43 PM
ccfulton's Avatar
Poly bushings firm up the handling and last longer than the rubber ones, so it is probably the last set you will need to install.
On the down side some might find the firmness too harsh and in cold weather they have been known to groan a little.
Old 09-04-2013, 12:01 AM
tberg's Avatar
Received 2,579 Likes on 1,419 Posts
I also installed the Powerflex set, and while they eliminated a lot of the steering shimmy and firmed up the ride, they groan all of the time not just in cold weather. Going over any bumps, humps, dips...they just moan and groan. Were I to do it again, I'd probably choose rubber bushings.
Old 09-04-2013, 06:11 AM
I wouldn't mind a more firm ride, not having to change them again is a plus, but I could absolutely not live with the moaning and groaning. I do, however live in a tropical island. Is it at all possible that the warmer weather here might decrease the moaning and groaning?
So, according to the picture I posted, which bushing is that? It's right next to the oil filter. I only plan on buying that one for both wheels. My budget currently doesn't allow me to buy the entire set.
Old 09-04-2013, 02:29 PM
ccfulton's Avatar
That looks to be the front lower control arm front bushing.
I don't have any real trouble with groaning even with all of the bushing being powerflex brand. I've only heard it a couple of times, and only when it is near freezing temperatures or lower. There is a good bit of grease on them and the place I take the car for service does lube the bushings when the car is in for service, so that might help.
But if it's a concern, the rubber OEM bushings are not a bad thing, I just prefer the somewhat firmer ride.
Old 09-04-2013, 09:33 PM
Thanks ccfulton, that's actually good to hear. I guess I might go for the powerflex part then. I am actually used to firm ride thanks my dad's history with cars. Can I expect the car's handling to go bonkers by having the front lower control arm bushings be the powerflex and the rest be the stock ones?
Originally Posted by tanngo
HOLA AMIGO , te escribo desde argentina , se que hablas español , me ayudaste unas veces con las traducciones ... espero que traduzcas a los demas lo que voy a escribir ...
nuemero de pieza original de los bujes de barra inferior es ) ; MNE1360CA (x2)
llevan 2 delante y dos detras . los 4 inferiores son iguales .
yo los reemplaze en mi xkr 2001 hace 1 semana . solo los 2 delanteros . luego lleve alineacion y no se modifico los paramertros . se saco la barra inferior que porta el buje , no la barra de rotula . es simple . pero se necesita especialista con prensa . en ebay hay miles de pares de bujes . espero haber colaborado . atte saludos
Also, I got an email from tanngo, our Argentinian friend, asking me to translate the contents of the email on this forum, although, I'm unclear whether he meant it for this thread. Either way, I'm taking a crack at it now.
Originally Posted by tanngo-translation
He says the original part number for the lower bar bushings is MNE1360CA (x2). He says there are 2 at the front and two at the back. He says all four of them are the same.
He replaced the two front bushings and then had his car realigned. He states the parameters were unmodified. The lower bar that holds the bushing was removed, not the ball bearing bar. He says a specialist (or is it special tool?) is needed. He finally says that there are lots of bushings which can be purchased from ebay.
I hope to have helped.
I'm gonna google that part number he gave me there. I hope it's what I need. What's the price difference between the stock bushings and the power flex?
Old 09-04-2013, 09:47 PM
So, if I've got this right, it's $65 plus shipping for the poly bushes.
Jaguar XK8 XK8R Front Lower Wishbone Front Bushing
and, it's about $41 plus shipping for the stock ones from Gaudin. Jaguar Parts - Direct JPLV Porsche Parts.com
If I've got the right ones, then I have a real dilemma. I can't choose! I was announced that my scholarship is going to be paying on the 20th of september. So, on the 20th I've got $350 expendable. The poly set would ring me about $131.98 + shipping and about $80 to have both of them installed. That's a total of $211.00... on the other hand, the stock ones from Gaudin would be $82.86 + shipping and $80 more for labor (the mechanic is quoting me $40 a bushing) so that would be $162.86. Without factoring shipping, does a saving of $48.14 a justify going for the less firm, more likely to wear out again part?
This is all assuming I've picked the correct part.
Searching on ebay, I'm seeing much much lower prices, but I'm not sure I'm looking at the correct part, even though I've got the part numbers.
As you can imagine, that's the last problematic mechanical thing to fix on my car. And the clunking sound is driving me nuts! After I'm done with that, I'd look working on the aesthetics, little by little.
Old 09-04-2013, 10:52 PM
ccfulton's Avatar
Changing one bushing to polyurethane vs a new rubber one probably won't make much difference to the feel.
As for the life, it is all relative. The car is 13 years old now and needs a bushing. Will you keep it that long again?
Old 09-05-2013, 04:06 AM
RaceDiagnostics's Avatar
That does not look like an OEM bush, more like a poly one
Old 09-05-2013, 10:09 AM
ccfulton, I probably might keep the car longer than that. I've completely fallen in love with it. I might, however, eventually trade up for an XKR, but, this car has some sentimental value to me.
Race, what makes you think that's the poly bush? It looks pretty banged up.
Looking at my current financial situation, I think I'm going to buy the OEM part.
Old 09-05-2013, 10:23 AM
The shape of the black bit, the rubber ones are more conical in shape in cross section and the poly ones are cylindrical.
Old 09-05-2013, 12:47 PM
Do you think it's at all possible that the previous owner changed my bushings to the poly set? If the poly set is supposed to last longer, what caused that one to go bad?
I've always believed the ride on my XK8 was naturally more firm, at least, compared to my dad's VDP.
Old 09-06-2013, 09:29 PM
Just a quick question. Is this the correct part? Is it the OEM one?
Jaguar XJ8 XK8 Front Lower Suspension Control Arm Bushing Set of 2 URO New | eBay
Old 09-07-2013, 08:34 AM
It is the same shape as the OEM one but is aftermarket.
Old 09-07-2013, 09:46 AM
So it's probably made of a lesser material?
Old 09-07-2013, 10:33 AM
Jag#4's Avatar
Have used various Uro parts on mine and have been very satisfied. Quality seems fine and has to be better than the original 13 year old bushes you likely have on now.
Old 09-07-2013, 10:36 AM
That's good to hear. I just can't seem to contact them and find out if they will ship to Puerto Rico, which is technically, in the US.
Quick Reply: Front Suspension Bushings
