head gasket replacement XKR 1998
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
Hi I am about to repair the head gaskets on my 98 xkr lots of white smoke from left hand exhaust , combustion gasses in header tank so looks like heads are coming off , will keep this thread updated and post some photo,s as the jag comes to pieces in the garage. wish me luck !!!
Looking forward to seeing the photos.
Good Luck,
Had a couple of hours spare tonight so made a start on the headgaskets. Stripped off the throttle body, supercharger and inter coolers. There seems to be lots of new hoses fitted all over the engine, maybe this is a clue to why the head gasket or gaskets have failed. One thing I have noticed is the supercharger is quite noisy when rotated, sounds like a bearing needs changing.
Thanks Guys
the Jag engine is much more complex than any of my other cars, the yank is just so simple in design compared with this, and the rover v8 in TVR is very similar.
I was hoping to get more pics up but think they are too big will get one of my boys to sort them out
The Coupe (02-21-2012)
got back on the jag tonight took off the crank pully and timing cover another 200 bolts later and got the left hand head off see photos this gasket has failed in 3 places dosent look like OEM gasket either, no 1 piston on this side has had a steam clean,, although there is a lot of stuff to take off its not a bad job to do the only awkward bits were getting the crank pulley off, with the puller you have to pull it off a bit then tap it back on to release the tapered split washer thingy. a couple of the exhaust nuts were a pain but overall not too bad will continue and take off the other head maybe tomorrow night. One bit of good news is the supercharger I stripped it down there was hardly any oil in the gear end and the plastic coupler has worn out on the pegs. the rest of the charger looks perfect.
EZDriver (02-21-2012)
OK so I need new chains and tensioners,slippers, gasket set, water pump, head bolts, drive belts, supercharger coupling , supercharger oil and snout oil seal , engine oil and filters,sparkle plugs , anti freeze and of course heads pressure tested. and thermostat. anything I have missed that should be changed?
Diamonddave (02-22-2012)
You might think about installing new knock sensors, given the age of the engine and the fact that you have good access with the intake manifold off.
I've got a 1997 and both of my knock sensors are beginning to act up...both will need to be changed soon.
Like The Coupe, I've seen another engine manual recently and am fairly certain it was on the forum but I can't find it again.
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
It's not the 'JJM181515/70 - AJV8 Technical Guide' PDF which is in the sticky section. The other one appeared to have been scanned from a photocopy...........
