HOW TO: Adjust Windows to Eliminate Wind Noise (Video)FAQ
After I got done replacing the door latch I had to adjust the window. I had intentionally mis-adjusted it while the door microswitch wasn't working so that it wasn't banging on the A-pillar. Now that I've replaced the microswitch I can adjust the window properly. This video shows how to adjust it.
NOTE!: A couple of posts down below, Dennis pointed out the it isn't necessary to remove the door panel to access the in/out adjustment. You can get to it just by taking off the lens to the puddle light on the bottom rear corner of the door.
http://www.youtube.com/watch?v=o2tLlUpO6TI
The following 4 users liked this post by Reverend Sam:
Reverend Sam (02-27-2011)
Very good Reverend, I noticed you didn't mention the other 'glass tilt' adjustment next to the speaker also...in case you are happy with the lower part of the glass near the b-pillar, you can bring in just the top corner by adjusting that front tilt bolt. So many adjustments, I can see how this can get ugly real fast if one does not know what does what.
I was wondering where the entire glass stop bolt was located, I found the 'drop' stop, but not the 'all' stop. Mine needs to go up a bit.
I also found my 1/4 glass was stopping prematurely, possibly too tight of a seal at the top...but a little tug brought it up a bit, sealing that gap I was chasing...and instead of bringing angling the glass down to meet the 1/4 glass, I'm now going to make sure that rear glass travels up fully. Not sure how yet though....
