How to check your ECM ground
Old 02-23-2013, 03:52 AM
steveinfrance's Avatar
Default How to check your ECM ground
Apart from a bad battery one thing to suspect when odd codes get thrown is a bad ground somewhere.
It might help to know that the OBD port pin 5 goes to ground via the ECM while pin 4 is grounded directly.
Pin 16 is battery volts so you should see the same voltage between 4 + 16 as 5 +16, and the resistance between 4 +5 should be a fraction of an ohm.
The following 13 users liked this post by steveinfrance:
berlin1977 (02-23-2013), BobF (02-23-2013), britannia (02-24-2013), GordoCatCar (02-24-2013), heima (02-25-2013), JajJohn (02-23-2013), jimbov8 (02-23-2013), MRomanik (02-23-2013), oyster (02-23-2013), Pristine97XK8Convertible (03-11-2016), RJ237 (02-23-2013), Sir Alex of Yotto (07-04-2015), The Coupe (02-23-2013) and 8 others liked this post. (Show less...)
Old 02-24-2013, 10:00 AM
Pins 4- 16 is also an easy way to measure battery voltage without pulling the boot liners apart.
Bear in mind your OBD reader gets its power from pin 12 so leaving it connected will flatten your battery.
The following 2 users liked this post by steveinfrance:
clyons (02-24-2013), MRomanik (02-24-2013)
mbergen
10-23-2019 10:26 PM
rsa760041
23
09-25-2015 01:33 PM
XJsc-guy
09-25-2015 11:09 AM
abonano
25
09-25-2015 10:43 AM
avern1
09-08-2015 06:25 PM
Quick Reply: How to check your ECM ground
