Nikasil engine problems
Sorry about that here you go he has a great web site.
Gus
XK8 1999 113,000mi
XJ6 1995 155,000mi
Rav4 1996 258,000mi and counting
www.gusglikas.com/autorepair.htm
What it is what it ain’t and what it ought to be!
Don’t ask the question if you don’t want to hear the answer!
Gus
XK8 1999 113,000mi
XJ6 1995 155,000mi
Received 2,191 Likes
There are a lot of great posts on what to look for in a used Jaguar here: https://www.jaguarforums.com/forum/s...ad.php?t=29800
Hope you join us as a Jaguar owners.
tp
tp
Was on the phone last night getting the real facts on the Sulfur and the effects on the Nikasil eng. If it makes you feel any better today’s sulfur is <20ppm. If you have good compression and had not shown any evidence of starting issues you should be OK. However, fallowing Brutal’s suggestion is not a bad idea and I am working on that end now. The cylinder was has been a problem on the Nikasil 1997 – 2000 and Jaguar addressed it as cylinder washing. In fact they have a few TSB 303-52 & 303-35 relating to it, however, I do not have a copy of the TSB’s for you to read but I did put a few things together that may help and you can find them on my page at http://www.gusglikas.com/AutoRepairNoStart.htm . This is a continuing process and it has taken me time to get the real information. I will get it to you as I pull it together. For now do not panic over Nikasil just take care of it and be aware of the effects of a short trip.
GUS THE BULLETINS BACK THEN APLIED TO A TOOL THAT WAS SENT OUT TO ALL DEALERS IN THE LATE 90'S. IT MEASURED THE AMOUNT OF BLOWBY WITH THE ENGINE IDLING. IF UNDER WARRANTY THE ENGINE WAS REPLACED IF IT EXCEEDED A CERTAIN AMOUNT. BUT IT WAS FOR JAGUAR TO GET A RELIABLE MEASUREMENT OF THE ISSUE RELATING TO BLOWBY CAUSE WE WOULD RECHECK AGAIN DOWN THE ROAD. WE REPLACED A FEW ENGINES, BUT NOT THAT MANY AND WE'RE ONE OF THE LARGEST. I REC ENGINE RESTORE FROM PERSONAL EXPERIANCE. AND FROM 1 CUSTOMER I HAD THAT LET HIS OIL CHANGES GOTO 20K MILES AND HAD SO MUCH BLOW BY THE AIRFILTER AND HOUSING WOULD BE SOAKED. HE SAID HE WAS ALWAYS TOO BUSY TO COME BY..."WHAT, GO TO A QUICK CHANGE THEN CAUSE NOW YOU NEED AN ENGINE!"
ANYWAY AFTER THAT I TOLD HIM TO CHANGE THE OIL EVERY 3K, USE 10-40W INSTEAD OF 5-30W AND USE ENGINE RESTORE, AFTER A COUPLE OIL CHANGES AND CONSISTENT USE OF ENGINE RESTORE, HE WAS ABLE TO DRIVE THE CAR ANOTHER 60K MILES AND NO MORE OIL SOAKED AIRCLEANERS. THEN HE TRADED THE CAR IN ON WHAT I DONT KNOW. BUT THE CHIROPRACTER I GO TO FOUND OUT I WORK ON JAGS AND SAID HE HAD A GOLFING BUDDY THAT HAD A POS JAG THAT NEEDED AN ENGINE IN 4 YRS AND 80K AND SAID HE'D NEVER GET ANOTHER. THEN HE TOLD ME HIS NAME AND I LAUGHED. i SAID "DID HE TELL YOU HE DID 20K MILE OIL CHANGES AND THATS WHY THE ENGINE NEEDED TO BE REPLACED?" TO WHICH HE SAID "WHAT A DUMBAZZ, NO HE DIDNT MENTION THAT!"
YOU KNOW THERE ARE ALOT OF NIKASIL ENGINES OUT THERE STILL RUNNING STRONG, JUST REALLY DEPENDS ON THE CARE GIVEN THE ENGINE
Bigvettefreak (10-22-2011)
Brutal
If my 98 XK8 has 110,000 miles on the engine, Has no blow-by or starting problems, would you still recommend 10w40 and restore?
On a side note. just getting ready to put cam tensioners in it, Still has 1st gen tensioner in it, Lucky I guess.
for a quick plug, Ken at Motorcar LTD is the MAN. ordered everything from cam tensioner to water pump, hoses,body parts, everything I needed was in stock and shipped that day, Thanks
mdw1942 (01-23-2013)
Cylinder washing is a real concern with Nikasil block and is often caused by the unburnt fuel in the cold cylinder block. The information I am getting from the chemist will explain much of what is not known. And an FYI Sulfur was measured to be 300PPM in the year 2006!
My tensioners were both cracked at 65,000, but not badly. Be interesting to see what you find.
I've been using Pennzoil Platinum 5W-30 with 5,000 mi changes in my '99. Also brand name premium gas..so far no oil blow-by or starting issues, even after short trips. Not sure that I want to use any additional additives, unless there's a proven reason to. I know a lot of people swear by Marvel Mystery Oil but again, not sure its been proven to be helpful with Nikasil engines. Anyone have some information on lab tests, etc. that show a real advantage in using additives?
yep Gus, Sulpher has been going down in fuel (good), but Zinc has just about totally removed from oil too. was agreat anti wear, but screws with 02's
And Mike, I grew up in the SHOW ME state so I tend to not believe alot until I use it and "SEE" for myself...Just relating what Ive used and know has worked
yep Gus, Sulpher has been going in fuel (good), but Zinc has just about totally removed from oil too. was agreat anti wear, but screws with 02's
I agree with you and feel your idea and application of oil additives is right on.
