Now available: XK8 / XKR Navigation to Triple Gauge Cluster Conversion Harness Kit
Old 06-05-2011, 12:30 PM
WhiteXKR's Avatar
Received 2,985 Likes on 2,124 Posts
Thumbs up Now available: XK8 / XKR Navigation to Triple Gauge Cluster Conversion Harness Kit
If you dislike your outdated, non-upgradeable navigation system, now you can replace it with the timeless design of the factory triple gauges.
I have designed a triple gauge cluster harness retrofit that is easy to install - no soldering or special skills needed.
You provide the gauge cluster (new or used) and the wood trim bezel. This kit provides the harness to allow you plug the gauge cluster in navigation equipped vehicles and have it function properly. This add-on harness is not available from Jaguar dealers.
The kit includes the harness, a solderless ground tap connector, tie wraps and a wire pulling tool. The terminals and connectors have been thoroughly researched and are the same parts used to fabricate the original Jaguar harnesses.
The conversion takes about an hour. It also allows you to return to navigation should you ever wish to.
Please PM me (or email: whitexkr@comcast.net) if you have questions or want to purchase one. The kits sell for $79.95 plus $10 shipping in the US (overseas shipping by quote). At this time I can only accept Paypal or check.
Here are the installation details (revised June 6, 2011):
The following 5 users liked this post by WhiteXKR:
Arland Green (12-29-2014), CA Jag (08-05-2021), Frog (06-06-2011), kkloberdanz (08-13-2021), Redline (06-08-2023)
Old 06-05-2011, 12:43 PM
WhiteXKR's Avatar
A RHD version is now available.
Old 06-05-2011, 01:33 PM
Frog's Avatar
I got your PM and will try to take a look at my RHD setup tomorrow. I can't really see why it would be different to LHD, but I guess Jaguar's motto is "why do it simple when you can make it complicated"
Old 06-05-2011, 05:00 PM
WhiteXKR's Avatar
I am almost certain at least the wire lengths will be different, but if you can confirm the the connectors and openings are in the same relative position, I can figure out the length changes.
hlgeorge (06-05-2011)
Old 06-05-2011, 07:47 PM
Fedoraja1's Avatar
This is great WhiteXKR. I'm sure many people will find this useful!
WhiteXKR (06-06-2011)
Old 06-06-2011, 07:25 AM
WhiteXKR's Avatar
Revised instructions have been added in Post #1 of this thread with some additional clarifications.
Please download this revised version if you plan on performing this installation.
Old 06-06-2011, 01:36 PM
Frog's Avatar
Old 06-06-2011, 01:48 PM
K.Westra's Avatar
Your projects are always so cool WhiteXKR. I'm glad I don't need this one though
Old 06-06-2011, 03:07 PM
WhiteXKR's Avatar
Thanks Keith. Maybe I can drop your top one of these days!
Old 06-06-2011, 03:32 PM
govatos's Avatar
Once again amazed and impressed. Great job!
Old 06-06-2011, 08:22 PM
WhiteXKR's Avatar
Frog- Yours is arguably one of the most beautiful XKRs I have seen. It is my pleasure to help you enhance it further.
Old 06-07-2011, 12:34 AM
Frog's Avatar
Thanks. It is going to look even nicer when I swap the 1950s TV set, sorry OE satnav, for those gorgeous - if useless - gauges
Old 06-07-2011, 12:41 PM
bassmania's Avatar
Great work WhiteXKR. Amazing!
Old 06-11-2011, 01:28 PM
WhiteXKR's Avatar
Default A Right Hand Drive version is now available
For those of you across the pond, a Right Hand Drive version is now available !
Frog (06-11-2011)
Old 06-11-2011, 01:34 PM
Frog's Avatar
Printing it now in anticipation of receiving your harness. Many thanks again for your hard work!
Old 06-11-2011, 09:02 PM
Spurlee's Avatar
Default Excellent work!
This is a very useful conversion and a benefit to the XK8 community.
Old 06-20-2011, 04:01 AM
Frog's Avatar
My wiring harness arrived this morning. Installing as I type...
Old 06-20-2011, 09:06 AM
K.Westra's Avatar
Do you have more than 2 hands?
Old 06-20-2011, 10:27 AM
Frog's Avatar
Job done! WhiteXKR's harness is very well put together and his instructions make for an easy, if slighty fiddly (reading glasses recommended!), install.
If anything, his harness is almost over-engineered, but this only makes the install simpler and obviously I would prefer too much quality to not enough. From start to finish, it took me just over 2 hours, but I was being REALLY methodical and deliberately slow, so as not to mess things up. Having done it once, I could do it all again in under 1 hour now.
Anyway, here's a quick picture of my fully working gauges. Many thanks to WhiteXKR for his hard work and perseverance with this mod
Now I just have to wait a couple more weeks to get the elm veneer panel back from the UK.
WhiteXKR (06-20-2011)
Old 06-20-2011, 01:14 PM
WhiteXKR's Avatar
Nice job Frog completing the very first Right Hand Drive installation !!
Enjoy your refreshed ride !
Quick Reply: Now available: XK8 / XKR Navigation to Triple Gauge Cluster Conversion Harness Kit
