Octopus Hose Removal - Access behind elec box?
Old 09-17-2013, 08:04 PM
GordoCatCar's Avatar
Default Octopus Hose Removal - Access behind elec box?
Is there a trick to removing and reinstalling the octopus hose along the firewall. It runs along the firewall, behind a black electrical box. Which end is pulled out first? Drivers or Passenger side? Likewise which end is threaded behind the electrical box first?
I have the TB removed. All the Norma clips and other clamps are removed and the hose is loose. I am trying to remove the two (2) hoses that run behind a black 4x6" electrical cable box. I have the electrical cable box out of its bracket/holder, but access for the Octopus behind the bracket is still very tight.
Before I start cutting out the old hose and jamming the new one behind this box, I was wondering if I am missing something obvious. Thx. Gordo
Old 09-17-2013, 08:28 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Never had a reason yet to mess with it but does this help?
Attached Thumbnails Octopus Hose Removal - Access behind elec box?-heaterundrehood1999xk8.jpg
Old 09-17-2013, 09:24 PM
Thanks Gus. The Octopus was hung up on a zip tie hidden behind the electrical cable bracket. Once I cut that, I could wiggled it out from the Drivers Side.
Lots of wires, cables, hoses and tubes. Octopus is a good name.
clubairth1
29
05-10-2024 12:57 PM
aholbro1
08-05-2021 05:02 AM
dsnyder586
04-04-2019 02:38 PM
cissdm
05-03-2016 06:02 AM
XJsc-guy
11-23-2015 01:56 PM
Quick Reply: Octopus Hose Removal - Access behind elec box?
