P0121 abs/trac limp home
I've had a reoccuring problem with the ABS/Trac yellow light coming on and attributed it to dirty sensors. Recently it cleared up entirely.
Th is afternoon I got the full dump: red light and limp home and code P0121. I cleared the codes, cleaned (again) the Throttle Body plugs and it is OK for the moment.
I read somewhere about a gold plug repair/replacement kit as part of a P0121 fix but can't find the link now.
Anyone know where I can get one of these kits?
Thanks!
Thanks!
I think this is what you are looking for http://www.gusglikas.com/AutoRepTB.htm If the plugs are not the cause of the problem you may need to consider that you may have a TB problem.
I've had problems with the connectors before and cleaned and reseated them with good results.
I think this last event is related to the intermittant ABS/TRAC code I'm getting which is, in turn, related to dirty wheel sensors (I hope) or a bad harness to the RF wheel - that's what the dealer code reader picked up (a $250 repair)
I cleared the code and it runs fine for now. I'm going to hobble it home and do the simple stuff first - clean the sensors.
I might be wrong but the way I see it is that the P0121 indicated a Throttle Position Sensor failure (TPS) this in turn inhibits the “Limp Home Mode”, Inhibits – Idle Speed Control, Cruise Control & Traction / Stability Control. If it were me I would clean and tighten the plug connectors or replace them with the gold tip plugs. If that failed to clear the problem I would have a test done on the TB and this could be conducted by Jaguar. I might be wrong but I am not convinced that it is anything other than a poor connection or defective TB. But I am not an expert!
http://www.gusglikas.com/images/Auto...J27%201999.pdf
I'm the OP and just resolved the issue, I think.
First, I cleaned the sensors using the excellent instructions. No change.
Second, I bought a new battery. No change.
Finally, I coughed up $150 for the *********** to scan it and per the code replaced the RF ABS Sensor Wire (P/N LJD3410AA) It ran $44 at www.parts@jaguarparts.com, Davis Auto Group) and 1/2 hour of my time vs. $290 for the dealer to do it..the process is really simple.
The code didn't shgow on my inexpensive Actron reader, but might on a better one.. I'm only 2 days into the repair, so I don't really know if it's fixed...
ManoFlem
16
09-25-2015 09:29 AM
