Power steering leak
Orthodixie (02-17-2018)
https://www.jaguarforums.com/forum/m...s-repair-1282/
This is an easy repair! Check out this post I did last year on how I did mine.
The following 2 users liked this post by daddyo007:
Orthodixie (02-17-2018),
plums (02-06-2012)
I just fixed the same problem on mine. Tried replacing the o rings and that didn't work. Cut the hose back from the coupler and connected a 3/8" hose to the metal line and with a 3/8" brass hose barb connector reattached the new hose to the existing return line. Cost was about $5.00 in hose clamps, fitting and hose.
Sorry I didn't take any pictures but is a real easy fix. Just cut the hose back as much as you need to from the coupler and using 3/8 fuel line hose reattach the new hose to the metal line( it will push on over the lip on the metal line) and secure with a clamp on either side of the lip(so it doesn't come off) then using the 3/8 brass hose barb connector(Hardware store item) attach the existing hose to the new piece of hose with 2 more small clamps. I will try and get you a picture of what I did this morning. I hope this helps. When you get the o rings you will need to get AC type orings. I went to NAPA and had to buy a kit that had had what looked like the right size in the bag. Cost was $7.00 and still leaked.
I believe cjflyer is talking about this item
Brass Hose Connector
I'm not sure the brass will be compatible with the ps fluid. Give my fix a try.
It really does work at the leak point that you have. I just went further and replaced all the rubber lines from the pump to this factory quick connection.
Do either of you have a picture of what you did? I am going to take on this project while the weather is nice. The complete hose is $160 plus labor would put it about $500 so seems like what you did is the inexpensive and easy way to go.
Jaguar Forums - Jaguar Enthusiasts Forum - daddyo007's Album: Low Pressure P/S Repair
Hear is a description with pictures of what I did. It is still holding!
The following 3 users liked this post by daddyo007:
rusty37
04-05-2020 07:40 PM
Dicque
09-19-2015 12:53 PM
