Replacement of thermostat housing
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Okay, several of you said this would happen. The thermostat housing on my '01 XK8 ($54K miles) is cracked and slowly leaking. The dealership mechanic confirmed this fact today. But he wants $620 in parts and labor to replace it.
My search of parts via suppliers on-line says a replacement housing costs less than $100. So, is the dealer trying to rip me off? Is the replacement a complicated piece of work? Or is there more to it than just replacing the housing, i.e., the thermostat, gaskets and other stuff should be replaced as well?
This is a fairly common...and ongoing...problem with these cars caused by a plastic housing. Someone...sorry I don't know who....makes a metal housing that cures the problem permenantly. I would definitely find out where to get the metal housing and replace with that. BTW, $600 sounds like a lot.
This is one of those aftermarket items that comes from one source, and all of the vendors are selling the identical product. Welsh Jaguar has this kit for about $70.00, and I believe their are other sources with similar deals. I'm always glad to provide items such as this from my list of sources, but there has to be some return for the time invested. In the case of this kit, I don't think I can buy it for any less than you can from Welsh.
Andrew Bernstein
British Auto Care
Addendum: Atom just posted that he bought this kit from Motorcars, a site sponsor: that makes Ken the first guy you should give your business to whenever he can provide what you need at a reasonable price.
Andrew Bernstein
British Auto Care
Yes it was Gorto that had info about replacing the housing. Go to this link https://www.jaguarforums.com/forum/s...ad.php?t=13044. I hope to do mine this spring so I can use all the info available...
Good Luck!
Good Luck!
Hey Gus,
Want an exculsive for your site? I just removed a thermostat tower in ten minutes, without touching the intake or bending any of my tools. PM me if your interested, and I'll send you the procedure to post, so long as I get credit for it. Apparently nobody else has figured it out.
Received 2,190 Likes
Hey Gus,
