SRS/Airbag codes
Old 07-12-2010, 04:15 PM
Onca3's Avatar
Lightbulb SRS/Airbag codes
Pulled this data from the DTC B-codes and sorted.
XK SRS/Airbag Codes
(Number indicates number of blinks, for instance, 13 is seen as a single flash followed by a pause, then three successive flashes, often repeated several times)
13 - Crash data memory full
16 - Pass seat weight sensor CAN fault
17 - Pass spatial sensor CAN fault
18 - Pass airbag deactivate lamp circuit fault
19 - Airbag circuit status fault – driver
21 - Airbag circuit status fault – pass
22 - Side Airbag circuit fault – driver
23 - Side Airbag circuit fault – pass
33 - Seat Belt Pretension fault – driver
34 - Seat Belt Pretension fault – pass
42 - Impact sensor circuit fault – front
43 - Impact sensor circuit fault – driver side
44 - Impact sensor circuit fault – pass side
51 - Seat belt switch circuit fault – driver
52 - Seat belt switch circuit fault – pass
53 - Airbag audible warning circuit fault
54 - RCM configuration failure
champir (07-25-2023)
Old 07-12-2010, 04:31 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
Great find, I was always wondering what these meant. I cleaned it up a bit, and will add it to the FAQ section.
Old 07-12-2010, 04:33 PM
Onca3's Avatar
Thanks for the clean up -- looked good on my screen until I did the submit.
philwarner
25
06-26-2021 05:43 AM
bdboyle
09-16-2019 05:58 PM
Terry H
07-04-2017 05:48 PM
JCam
10-23-2016 08:27 PM
philwarner
09-02-2015 11:45 AM
Quick Reply: SRS/Airbag codes
