Stick up an down steering column fix...FAQ
Old 04-26-2011, 08:51 PM
Mish_Mish's Avatar
Default Stick up an down steering column fix...FAQ
I am still slowly going across the car, replacing those convertible hoses.
Anyways, while I am at it, I fixed my sticky steering column adjustment servo. Very easy fix, costs nothing!
If someone is interested, I could put a quick how-to together, ofcourse it would be nothing fancy, like Reverend would make
There will be no drama, no talking into camera and absolutely no nudity
The following 5 users liked this post by Mish_Mish:
Bigvettefreak (10-23-2012), greenshadow (12-30-2015), lord3194 (01-07-2012), Orthodixie (05-08-2017), RJag (04-26-2011)
Top Answer
04-27-2011, 07:59 AM
Mish_Mish's Avatar
Mish_Mish
Mish_Mish is offline
Ok, here it comes!
What causes this issue is Bosch part, believe it or not.
Motor that controls the up and down is mounted right under the steering column (see picture), on one end it has little drive shaft, on the other it has potentiometer assembly. This assembly is very hard to spin and this is due to one very agressive spring washer. What happens is, when you try to adjust the column, motor jerks for a split second and then, due to excessive load, relay powers it down. Helping steering wheel up, or down does not help either, because it is driven through a worm gear... anyways, long story short:
1. Take off kick panel above the pedals, it is 2 8mm bolts, maybe 10 mm.
2. Take off motor-reducer aseembly, below the steering wheel. It is bolted on two allen style bolts, I think they are 5mm.
Please note that there is a shim, under motor assembly, for what reason I do not know, I did not re-install mine, because bolts are rather short, so I decided to give them couple more threads deep.
3. Unplug electric connector, it come out easy.
4. Slide off an open potentiometer assembly hosing, it has one screw and 2 little tabs to pull. It is Bosch made, so plastic is very strong, nothing breaks.
5. flatten the darn spring washer, or remove it of you like, I flattened mine with my fingers. You will see how much easier it will spin, after you put it together. Do not forget to add more lubrication, if you must.
6. Re-assemble motor assembly.
7. Bring the steering column up, or down manually, by spinning little drive shaft by hand. Now, connect electric cable to motor assembly, check if it works and then run it up, or down (with column adjustment knob), depending which way you moved the column earlier.
8. Slide motor end of the drive shaft into the column end.
9. Reinstall motor back in place, with, or without shim.
The end!
Attached Thumbnails Stick up an down steering column fix...FAQ-p1030919.jpg   Stick up an down steering column fix...FAQ-p1030917.jpg   Stick up an down steering column fix...FAQ-p1030916.jpg   Stick up an down steering column fix...FAQ-p1030915.jpg
Last edited by H20boy; 10-04-2011 at 11:31 PM. Reason: made big pics from your thumbs
Old 04-26-2011, 09:45 PM
ken qv's Avatar
Heck ya... mine will stick some day and when it does you don't want
to feel guilty do you?
Old 04-26-2011, 10:02 PM
Reverend Sam's Avatar
Received 1,262 Likes on 565 Posts
I'd love to know how to fix it. Some days mine works fine, other days it sticks. It just hasn't bugged me enough to try to fix it yet.
Old 04-26-2011, 10:03 PM
RJag's Avatar
I'd luv to see how you did it. My column just quit moving for me and it's on the to do list. Thanks, it's appreciated.
Old 04-26-2011, 11:19 PM
Friarshuck's Avatar
Put me down as interested also. Mine works fine in warm weather, but if it's under about 70 degrees, not so much. Thanks
Old 04-27-2011, 05:49 AM
Felipe Pr's Avatar
I will like too see it also. Thanks.
Old 04-27-2011, 06:50 AM
Lifts's Avatar
Put me down. Same problem .
Old 04-27-2011, 07:59 AM
Mish_Mish's Avatar
Ok, here it comes!
The end!
Attached Thumbnails Click image for larger version
ID:	9887   Click image for larger version
ID:	9888   Click image for larger version
ID:	9889   Click image for larger version
The following 60 users liked this post by Mish_Mish:
2002XK8Orlando (05-04-2011), arttomlin (03-31-2015), Bakewell (08-22-2017), bcprice36 (05-11-2017), Bigvettefreak (10-23-2012), BlkCat (08-23-2011), Blue XK8 (06-18-2013), BobF (06-05-2011), Brian XK8 (05-09-2017), Burdedw (02-28-2014), cat8881 (04-20-2012), CharliePar (06-20-2017), CorStevens (03-29-2018), Cynthia Clements (07-20-2012), Davebc (11-03-2013), enderle (12-16-2012), EZDriver (09-11-2011), Fla Steve (04-27-2011), flydutch (06-08-2011), Frog (06-09-2011), Geoff41 (06-30-2015), Gheticle (01-01-2020), GooseTx (09-10-2019), H20boy (10-05-2011), Harryk (04-27-2011), Hdpartsman00XKR (11-22-2012), Ironheadvette (11-10-2017), Jag Pilot (08-06-2015), JAG06 (05-06-2011), JajJohn (11-21-2012), jammin012 (02-04-2015), K.Westra (04-27-2011), kippy (06-09-2011), larueb (11-08-2015), lord3194 (01-07-2012), mc_jag (05-05-2016), MDWEDER1 (11-11-2023), MFoncerrada8 (11-03-2013), mkrion (04-22-2015), obwoodie (11-26-2015), OregonJag (05-06-2011), Orthodixie (04-25-2017), or_blk_XKR (11-03-2013), piper 888 (07-13-2019), Platinum XJR (12-06-2013), Pristine97XK8Convertible (11-09-2013), reb1999 (07-27-2015), Richxk8 (04-29-2015), scardini1 (09-06-2012), simonfradd (08-22-2022), skymark (04-23-2018), smtguy (09-13-2015), SteveJacks (09-11-2011), taxman (05-09-2017), test point (05-05-2011), TheoJones (10-26-2011), toaster (03-29-2018), TrevLevin04XKR (07-19-2018), wcnesta (09-29-2012), Wide_Tyres_2 (04-01-2018) and 55 others liked this post. (Show less...)
Old 04-27-2011, 08:17 AM
K.Westra's Avatar
I'm adding this to my summer To Do list. Thanks
Richxk8 (03-28-2013)
Old 04-27-2011, 08:38 AM
Dave S's Avatar
Man, wish I had that when mine died. I had my mechanic replace it for me. Of course, the fact that I couldn't fit well under the steering wheel was a problem too...(it's TIGHT!)
Dave
Old 04-27-2011, 09:45 AM
guzzi svt's Avatar
Man, your work bench looks scary!
Thanks for the info!
Old 04-27-2011, 10:12 AM
Glenn Barickman's Avatar
Just so I understand...This is a fix for my steering column up and down movement. When I remove the key, my steering wheel go all the way in and all the way up. When I insert the key the wheel moves out, but only down a little. If I hit the memory button many times, it will move to the correct place and "ding" This is what we are talking about, correct?
Old 04-27-2011, 10:18 AM
Mish_Mish's Avatar
It's a part of it, yes.
There is also a manual adjustment that will work now..
Old 04-27-2011, 10:21 AM
Mish_Mish's Avatar
True, I need to clean it. It looks a bit crazy, because I worked on XJS last fall and you know how that goes...plus we had whole family of deer coming into our backyard, eating tomatoes and grapes, had to watch for them.
I was actually planning to organize it and paint bench top with nice epoxy paint.
P.S. I do good work though.
Old 04-27-2011, 10:28 AM
Harryk's Avatar
I would be very interested. I have the same problem...
Old 04-27-2011, 10:33 AM
Mish_Mish's Avatar
I already posted, see above^
Old 04-27-2011, 01:56 PM
ken qv's Avatar
Old 05-04-2011, 12:38 PM
Mish_Mish's Avatar
Any other success stories? Mine still works like a charm and I keep abusing it to make it fail, still no stick.
Old 05-05-2011, 06:30 AM
turbo68's Avatar
Added to my "to do's" ! Thanks for the post Mish! As you worked on this was there any place to "grease" the joints?? Mine started to make noise when it was going down and now sometimes it will make a grinding noise when going up. It is not all the time but it is temperature sensitive when it does it. Cooler temps are more likely to make the noise. I guess it could be just the motor doing it too but then it would do it more often and up, down , in or out i would think. Anyone else have a groan when the steering sets itself???
Old 05-05-2011, 06:50 AM
Planing to get to mine this week, will let you know how it goes. Thanks for pointing out I problem I didn't know I had, I guess.
Quick Reply: Stick up an down steering column fix...FAQ
